72 442 455 carb question
Hi, just put a stock Rochester carb on my not orig 455, it has the W-455 aluminum intake, when I tried to order a steel carb to fuel pump fuel line they asked if it was a W-30 car then the fuel line and choke tube were not available for a W-30 car, what the difference? Any one know? Thanks Phil from Milwaukee
No, the W-30 used an inline canister fuel filter that year, so one line went from the pump to the filter and the second from the filter to the carb. The choke pipe should be the same as for all big block Qjet cars.
Thanks for the reply, I know see the canister in the front rt wheel whell, does anyone have a diagram here the vacume carb ahd fuel canister lines attach, still canot confirm my car is a W-30, did a 350 car come as a w-30 or only a 455 car? I think the previous owner tried to make a w-30 car, my vin show a 350 was stock motor, Thanks Phil
