1980 Olds Cutlass
The first question is, is it a V6 or V8? These cars were available with either Olds V8 motors or Chevy V8 motors (in addition to the Buick V6), and if it's been changed it could be almost anything. An Olds V8 will have an oil fill tube at the front of the engine above the water pump. A Chevy will usually have the oil fill cap on one of the valve covers. If it is an Olds motor, there is a casting number on the little shelf next to the oil fill tube. Post that number here and we can tell you what the block is.
As for this particular engine, the casting numbers sound like an Olds 307.
1969camaross350
Oct 1, 2025 03:22 PM
