Timing chain
Captain of my ship
OK I have taken a peek at the timing chain and gears. I wedged the top of the plate out enough that I could get a long thin screwdriver to check the slack. THIS IS JUST AN ESTIMATE. I figure that there is about 3/4 inch or a little more of slack in the timing chain. As far as the gears go what I could see looks ok , so does the chain. I could see no evidence of any coating on the lower gear , looking down at it from the top all the teeth I could see on the top appear shiny and clean and also look uniform. I know that can not tell me the whole truth about the condition but from what I could see. My main concern is the slack in the chain , I would appreciate anyone with some experience in this to give me advice and options if there are any. Thanks
Captain of my ship
timing chain
It appears the chain is relativly new and so does cam gear so I will leave it alone , after i cleaned up behind plate lubricated and torqued bolts and waterpump down after some ultrablue.
