Info is tall 57/58 rear end in 55 olds 98
Old Oct 30, 2018 | 05:37 PM
Love1955oldsmobile's Avatar
I want to install a 57/58 complete (drum to drum) rear end in my 55 98 to get a 2.56 ratio. Hollender says it fits but no other details. Anyone made this type change and things to look out for besides shocks and u-joints? Thanks. Ron
Old Oct 30, 2018 | 06:36 PM
Tedd Thompson's Avatar
Should work but run a tape measure from drum to drum on both rear ends to make sure. This was a common hot rod swap back in the day when a posi was needed in the 55-56 cars. 57 Old's and Pontiac were the first limited slip rear ends around at that time should be the same on a open or limited slip rear end.... Tedd
Old Oct 31, 2018 | 06:04 PM
Yellowstatue's Avatar
I think '58 was the first year for a limited-slip. Also, the later axles are larger and longer. If the '58 axles are the same as '57 then go for it. I put a '62 Poncho diff into my '57 housing and put in '63 Olds axles in, cut 11/16" shorter.
Love1955oldsmobile
Oct 30, 2018 05:50 PM
1953olds88
Drivetrain/Differentials
Feb 29, 2016 07:20 PM
NZOlds
Sep 17, 2013 10:11 AM
johnbost
Jul 25, 2010 02:50 PM
