1108418 starterapplication.
Old Jan 24, 2019 | 04:26 PM
MY71W30's Avatar
I get a rebuilt starter in a parts lot. I know it’s a 455 Olds starter, numbers on it are 1108418 with a build date of 4E16. I am wondering if anyone could tell me what this came off of, and what the build date means. Thanks
Ed
Old Jan 25, 2019 | 10:23 AM
D. Yaros's Avatar
Are the numbers you give set out on a tag or stamped into the housing?
The part tag is an oval shaped and begins with a group of seven numbers then a blank space then a group of four more characters, these last four characters are the code for the build date as follllows: First number is one digit for the year -- 3 = 1963, 4 = 1964..., Second the letter represents the month-- A = January B = February C = March ... M= December, Third & Forth numbers are the day of the month (no 00 or > 31).
4 = 1964
E = May
16 = 16th
May 16, 1964
I do not believe Olds was producing a 455 c.i. engine in 1964? It was first offered in 1968.
Part Number 1108418
Status Obsolete
Superseded By
1108400 Obsolete
1876552 Obsolete
Model MOTOR-CRANK Standard: Series: 10MT
Product Information: APPLICATIONS: Chevrolet Camaro; Oldsmobile Toronado; Pontiac Firebird; Tempest; GMC / Chevrolet Trucks. Delco 10MT Series Starters; CW Rotation.
Old Jan 25, 2019 | 02:51 PM
MY71W30's Avatar
Is it possible to be a 74? I know it is a 455 starter. I removed it from the engine myself. Just don’t know what the part number comes back to. No tag numbers are stamped right on the housing. Thanks
Ed
Old Jan 25, 2019 | 08:05 PM
mrolds69's Avatar
I'm seeing Chevy, and it's probably 1974. You can't tell 64 from 74. Maybe BBC truck or 'vette .
Old Jan 26, 2019 | 11:09 AM
D. Yaros's Avatar
Ed
Could very well be 1974. This starter was used by GM for a number of years on a large number of makes/models
Old Jan 26, 2019 | 02:39 PM
MY71W30's Avatar
Old Jan 26, 2019 | 04:19 PM
stellar's Avatar
stellar
The field case with the stamp is from a 1974 corvette 350 with 4 speed trans. If it came off a 455 it has the wrong drive end housing for a vet. The vet would have a cast iron staggered hole mount housing. A 1974 date isn't worth a whole lot.
Old Jan 28, 2019 | 05:03 AM
MY71W30's Avatar
Thanks I’ll just use it for a future build then.
Ed
Blair1955
Jul 4, 2018 11:42 AM
May 13, 2018 11:29 AM
67442nut
Feb 23, 2016 09:12 AM
btw
Oct 26, 2015 07:31 AM
belairbob
Aug 7, 2011 04:21 PM
