70-72 Cutlass Trunk Lids ?
Old May 29, 2018 | 02:18 PM
shockrebuild's Avatar
How many different trunk lids are made for 70-72 Cutlass? I see postings for convertible or Supreme but aren't the convertibles rounded on top side and Supreme has sharp corner? The we also have the Cutlass Fastback style also correct? So I count three. Are some people just confused about Supreme/ Convertible. Has anyone ever rounded off a Supremes to use on a convertible?
Old May 29, 2018 | 04:12 PM
lshlsh2's Avatar
71 cutlass convertible
4door/convertible
supreme
"S"
Old May 29, 2018 | 04:18 PM
Yep, a fella in the local Olds club did this many years ago for his 71 Supreme convertible. He said welding and finishing the edge was quite a job.
Old May 29, 2018 | 04:28 PM
Originally Posted by lshlsh2
4door/convertible
supreme
"S"
Well, to be technically correct:
Town Sedan, Holiday Sedan, and Convertible (xx39, xx69, and xx67 body codes)
Supreme Holiday Coupe (xx57 body code)
Sport Coupe and Holiday Coupe (xx77 and xx87 body codes)
Keep in mind that the Supreme could have come as a four door, convertible, or notchback coupe. Not all Supremes used the same trunk lid.
Old May 29, 2018 | 05:53 PM
ragtopblue's Avatar
The Vert is definitely rounded ! And that would be the same for all Supremes, 442's and SX's since they are all the same body for the convertible 70/72. Not to be redundant !
Old May 30, 2018 | 08:07 AM
Also, to be yet more technically precise, the part numbers are many more than that due to emblems. The 4 door, Cutlass Supreme convert, and 442 Convert used the same lid, but with different trim holes.
Old May 30, 2018 | 08:20 AM
Well, yes and no. The replacement lids came without holes drilled, so there were only three P/Ns:
9877968 - 4257 body (Supreme notchback)
9852222 - More doors and Convertibles
9852218 - all 2drs except 4257 or convert.
Now, on the assembly line, these were drilled in the different patterns, presumably using "make from" drawings, and as such would each have unique P/Ns.
Old May 30, 2018 | 08:51 AM
Good point, but I would think they were pierced in stamping.
Old May 30, 2018 | 09:42 AM
Interesting, I have I guess a Supreme lid then with aftermarket wing . The lid was NOS in 80s and painted poorly yellow , then car was wrecked a short time later the last owner said. Am going to sell trunk lid so was wondering if any body guys have ever rounded off corners to make it fit a Convertible if someone needed ?
Thanks for all the great info guys
Old May 30, 2018 | 09:45 AM
I wonder what spoiler it has on it? I don't think the 72 H/O even had a spoiler.
Old May 30, 2018 | 12:05 PM
You're correct. None of the 72 Cutlass offerings included the deck wing as an RPO It was cancelled 3/31/71
Old May 31, 2018 | 05:03 AM
Not sure on spoiler thou I know the owner said he purchased it at the same time of trunk lid?
Old May 31, 2018 | 05:09 AM
Some pics
Bad prep job for paint
Old May 31, 2018 | 10:09 PM
Gary M's Avatar
Are there three bolts on each side holding the wing on or two on each side? I think the repops used two.
rhaberm
Feb 13, 2018 12:38 PM
olds3442
Mar 19, 2013 01:32 PM
tmatador
Oct 27, 2011 03:20 PM
nelsontj
Body work
Mar 8, 2009 05:03 PM
h-bomb
Dec 9, 2007 06:32 AM
