ID Help needed
Old Jan 18, 2019 | 11:07 AM
Schmidty's Avatar
ID Help needed
Hello all, just got a 72 Cutlass Supreme and need help ID'ing the heads on the motor as I need to get new Exhaust gaskets. I did a lot of research and finally found out that the Block is a 1972 Pontiac 400, but the heads are Olds I believe. There are numbers on them, G62J and M62D they are bronze in color, but that could be a pain job. If someone can help that would be great. The car needs work, but will be drive able once the exhaust is fixed and some of the wiring is fixed. But that is a later project.
Old Jan 18, 2019 | 12:06 PM
I don't think that is possible.
Here's a site for decoding Pontiac head numbers.
http://www.wallaceracing.com/head1.htm
Old Jan 18, 2019 | 12:23 PM
CRUZN 66's Avatar
Olds Fever
Any chance you can provide a photo of the engine in question??? It's very doubtful there are Olds heads on a Pontiac block...
Old Jan 18, 2019 | 12:41 PM
Schmidty's Avatar
I am new to the car stuff. But that is what it is looking like. Here are some photos I have taken. If you want a different angle let me know, but photos are kinda hard with all the stuff in the way.
Thanks for all your help so far.
Old Jan 18, 2019 | 01:46 PM
That is a Pontiac motor. You'll need to check a Pontiac site for ID info. It is not physically possible to bolt Olds heads onto a Pontiac block.
Old Jan 18, 2019 | 03:35 PM
jcdynamic88's Avatar
i would change the motor out while i was replacing the gaskets. my .02
Old Jan 18, 2019 | 04:26 PM
CRUZN 66's Avatar
Olds Fever
A 62 head casting code should be a 68/69 400 Pontiac engine...
Old Jan 18, 2019 | 04:28 PM
Interesting that it's a G head.
Old Jan 18, 2019 | 04:38 PM
When I bought my 69 it had a 455 Pontiac engine in it. The guy left the Olds frame mounts in place, took the Olds engine mounts, and elongated the bolt holes to match the Pontiac engine. I had a lot to learn about anything automotive, and even more about Oldsmobile in particular. The guy told me it had a 455, (I told my dad it was a 350 &#128526 I didn’t question him. Imagine my surprise when every part I tried to buy for the engine was wrong. The counter guy finally decided to look at the engine, turns out he was a Pontiac guy and knew exactly what it was. I was happy it ran, and would absolutely destroy the rear tires. He also told me it posi-trac, I couldn’t wait to find out if that was true. Of course, it didn’t take much engine to smoke the girly-man 205/70/14 tires that were on it.
Mikesmith455
Aug 11, 2018 10:00 AM
Chicagoshane
Jul 12, 2017 01:51 PM
Jbliss77
Feb 29, 2016 05:32 AM
junkyard junky
Nov 29, 2015 07:12 AM
LadySkye1080
May 16, 2007 09:23 PM
