Will this fit | 72 Cutlass trans, drive shaft, rear question
Old Jan 5, 2019 | 04:50 PM
Brians1's Avatar
My project is going well for my 72 and im reaching a spot where I need to see if this is a doable decision im thinking about
  • Current Motor and trans is 350/TH350/8.5 inch 10 bolt rear - will be swapping in a 455/Th400
    • My 455 is not fully built yet (may not get there till Mach/April) - gotta keep wife off my back on spending too much money
    • I have a TH400 I got out of a 69 Firebird and just sent it off for a bench rebuild at a really great shop
    • I just sourced a used Driveshaft from a fellow forum member it was from a 455/Th400 car - so a "direct bolt on" for my prescription mentioned above
    • I have a 3.73 posi 12 bolt rear end from a 69 GTO my coworker is giving me
  • My question is this:
    • My current TH350 trans is leaking all over the place and I do not want to even think about fixing it.
    • Can I pair up my new TH400 (once I move the cross member back) and the driveshaft I sourced, with the new 12 bolt rear end?
      • This gets me closer to my 455 swap as well
      • I know I will need the various TH400 item such as the longer trans cooler lines, the kick down switch, etc
I just want to know if I can take this step now of the trans, driveshaft, and rear with the existing rocket 350..I know with the 455 motor its a no brainer.
Thanks for taking the time
Brian
Old Jan 5, 2019 | 07:05 PM
Gerald Nickels's Avatar
If you use the 350 trans a bolt in but 400 trans you need to cut drive shaft and find a yoke for trans. Need 455 manifolds.
Gerald
Old Jan 6, 2019 | 03:53 AM
Brians1's Avatar
I have a driveshaft from a TH400 / 455 car (with the yoke). Wouldn’t this fit ? I just need to know if the 350/TH400 the same length as a 455/TH400? If so then I should be good to go, correct ?
Old Jan 6, 2019 | 10:18 AM
I once swapped the O-Type rear in my car for a Chevy 12 bolt rear and used the same driveshaft. I had to use a conversion u-joint to go from the BOP driveshaft to the Chevy rearend.
Old Jan 6, 2019 | 10:47 AM
RetroRanger's Avatar
72 Olds CS
I think the answer is yes, but we don't know what 455/400 car the DS came from. For example I assume it was another olds a body, but idk if for example the 72 w 455/400 and 10 bolt corporate rear driveshaft is the same as say a 70 455/400 w a 12 bolt Chevy rear ( Canadian car) or o type rear ( us car) driveshaft. In short we need more info I do know if it was from a big car w 455/400 it's likely to long
Old Jan 6, 2019 | 03:52 PM
Brians1's Avatar
Actually the driveshaft I sourced came out of a 71 442 with a 455/TH400.
Old Jan 6, 2019 | 04:32 PM
At minimum you need the conversion u-joint. I can't comment on the driveshaft length difference between an 8.5" 10 bolt rear and a Chevy 12 bolt rear.
Old Jan 6, 2019 | 05:00 PM
Brians1's Avatar
Well I can still use my original 8 1/2 inch 10 bolt. Since my buddy is giving me this 12 bolt I still need put some money into it to get it overhauled. I wonder if it’s just worth the money for me to swap out the gears in my 8.5 10 bolt to the 3.73 posi??.....is that pretty straight forward ? If so then I should be able to do exactly what I want for now , Rocket 350 paired to TH400 with the driveshaft mated to my 8.5 10 bolt. And when I finish my 455 then all I’m doing is a motor swap
Old Jan 7, 2019 | 05:11 PM
72 Olds CS
yes i would keep the 10 bolt and make it easier MonZAZ on this site can help w parts needed and has stated its plenty strong enough for most BBO combos.
Brians1
Drivetrain/Differentials
16
Sep 26, 2018 06:10 PM
Charly9g
Jul 18, 2014 03:13 PM
815Cutlass1972
Mar 3, 2014 06:22 AM
Freddy B
Sep 20, 2013 07:20 PM
Cooter71
Oct 30, 2011 08:02 PM
