Toronado killing when leaving red lights
Sounds like a fuel delivery problem. First thing to check, make sure when the go pedal is pressed you are getting squirts of fuel into the carb. Engine OFF. Wear safety glasses
To check, remove air cleaner. Observe the throttle body and move the throttle through its travel.You should see two streams of raw fuel squirt out immediately.
If there is a delayed response or no fuel viewed during the throttle movement, you need to replace the accelerator pump in the carb which means a carb overhaul.
Arrowstorm
Jan 28, 2016 06:56 AM
