Toronado killing when leaving red lights
Old Sep 22, 2018 | 03:02 PM
Rob85's Avatar
My 85 toronado is running fine but it kills whenever I take off from red lights. It starts back up tho. What could be the problem?
Old Sep 22, 2018 | 03:30 PM
72455442RA's Avatar
your suppose to take off on GREEN lights ... not RED .... at least around here ... but I dont get out much anymore
Scott....
Old Sep 22, 2018 | 07:58 PM
don71's Avatar
same but different
Sounds like a fuel delivery problem. First thing to check, make sure when the go pedal is pressed you are getting squirts of fuel into the carb. Engine OFF. Wear safety glasses
To check, remove air cleaner. Observe the throttle body and move the throttle through its travel.You should see two streams of raw fuel squirt out immediately.
If there is a delayed response or no fuel viewed during the throttle movement, you need to replace the accelerator pump in the carb which means a carb overhaul.
Old Sep 22, 2018 | 08:20 PM
Rob85's Avatar
Thanks a lot Mr don. I changed filter earlier and it's still doing the same thing. I'll try to find someone who can overhaul the carb. Thanks
Old Sep 22, 2018 | 10:11 PM
blakes7's Avatar
When I had that problem, it was a lot of dirt in the gas tank clogging the pickup screen.
cougla
Jun 8, 2018 08:22 AM
harascho
Mar 21, 2017 02:54 AM
denf221
Jan 30, 2017 02:30 PM
Arrowstorm
Jan 28, 2016 06:56 AM
Seff
Jun 1, 2012 12:02 PM
