1970 Cutlass Steering Wheel
Standard steeling wheel process.
Remove the horn pad. Two screws from the back - usually phillips, sometimes someone put in a sheet metal screw with a hex head.
Disconnect the horn contact by pushing in and turning to unlock it. (it'll make sense once the pad is loose)
Remove the big nut.
Use a steering wheel bolt puller. You can rent them at parts stores. Cheap ones are fine.
Install is the reverse except you don't need a puller or anything. Just slip the wheel on and get real hard on the nut - 30ftlbs or more.
Remove the big nut.
70sdream
May 23, 2016 09:33 AM
