remove a grease fitting from lower ball joint
Old July 22nd, 2018, 04:55 PM
joseph44's Avatar
Hi Everyone Question: Can anyone tell me how to remove a grease fitting from the lower ball joint? I tried an easy out but the fitting keeps turning I don't want to replace the ball joint if I don't have to. I have no Idea how the end was broke off. Any help would be greatly appreciated and keep on cruising.
joseph44 is offline
Old July 22nd, 2018, 05:12 PM
Sampson's Avatar
Some replacement grease fittings were " pound in "and not threaded. My bet is someone installed one of these somewhere along the road. I would take a pair of vice grips and get a good grip and try to pull or pry it out.
Sampson is offline
Old July 22nd, 2018, 05:37 PM
therobski's Avatar
If the easy out keeps turning the fitting at least it has a grip? Can you get something on the end of the easy out and tug on and pull it out? What year of car? I never heard of a pressed fitting zerk fitting-must be a pre-64 sweetie at least??
therobski is offline
Old July 22nd, 2018, 08:33 PM
OLDSter Ralph's Avatar
"Pressed in" grease zerks have been around for years ! It costs more to drill and tap threads. Use a slidehammer arrangement to pull the zerk out.
OLDSter Ralph is offline
Old July 23rd, 2018, 05:34 AM
Sampson's Avatar
Looks like this!
Alemite® Drive Fittings
Used extensively to avoid tapping costs in a wide variety of applications
Alemite serrated shank grips securely and simplifies the replacement of damaged fittings in old or oversized holes
Recommended only for low and medium pressures
Sampson is offline
Old August 11th, 2018, 01:57 PM
therobski's Avatar
I keep learning new things everyday. Thanks for this info....
leroycjr
20
January 10th, 2018 03:48 PM
AJFink
July 11th, 2016 06:47 PM
defiant1
March 16th, 2015 09:44 AM
midrange
April 11th, 2012 06:45 AM
RATCHETMASTER
Brakes/Hydraulic Systems
October 20th, 2011 07:32 PM
Quick Reply: remove a grease fitting from lower ball joint
