442 VIN and body tag
Old Jan 26, 2017 | 05:37 PM
EngineErnie's Avatar
EngineErnie
I have a 1968 442 convertible (by VIN) but the body tag codes as a regular cutlass
How do I know this is a true 442 convertible even if the body tag says otherwise
I'm not able to upload photos but the relevant info is below:
VIN 344678M3708xx
Body tag 68-33667 LAN 376600
The VIN and body tags don't look to be molested or altered
Old Jan 26, 2017 | 07:52 PM
2blu442's Avatar
Since your vin has the correct numbers for the 442 your fine. Its been well documented that in 1968 442's were built with the trim tag located on the firewall using the Cutlass number not the 442 number. John
Old Jan 26, 2017 | 08:24 PM
stevengerard's Avatar
As John said, your VIN says its a 442
Old Jan 27, 2017 | 09:08 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Common well documented subject here. Do a search(s). The hull manufacturer, Fisher Coach Works, didnt care if it was a Cutlass or a 442. So most Olds Cutlass A bodies coming from Fisher indicated 336. It was turned into a 442 at the Olds plant where it obtained its VIN tag. I say most because a few of them did get 344 Fisher tags at other plants such as Fremont. My 68 442 Fremont Z code car has 344 on the firewall and VIN tag.
Old Jan 27, 2017 | 10:54 AM
EngineErnie
What sources of publications out there discuss this?
Old Jan 27, 2017 | 01:06 PM
The Fisher Body Manual for both 1968 and 1969 specifically mentions this issue on Oldsmobile A-body cars in the front section. The model and body style table in the parts book also documents this, as I've posted below. Note the footnote in the middle of the RH column.
Old Feb 11, 2017 | 12:07 PM
EngineErnie
Thanks Joe. Can you rescan and post the left side of that page with the numbers of the high performance V8?
Old Feb 11, 2017 | 03:48 PM
Here ya go.
ironlou399
Aug 9, 2019 01:08 PM
Octania
Feb 10, 2015 10:51 PM
knoggin
Apr 17, 2014 01:48 PM
Parting-out-a-olds
Jan 6, 2011 04:06 PM
DesertToro
Jan 16, 2007 07:10 PM
