Air cleaner base with HEI?
Old Nov 6, 2016 | 07:48 AM
grmchne78's Avatar
On my 70 Cutlass Supreme, I want to switch to factory HEI, which is not an issue except, the factory air cleaner base looks to be a clearance issue. I'm sure it can be modified to work, or the entire base be raised, or a carb spacer, etc. what (other than a chrome air cleaner) have some of you guys done?
Old Nov 6, 2016 | 08:54 AM
svnt442's Avatar
Your best bet would be to find one from 1975 and up if you want a stock air cleaner housing. They offset it forward and dimpled the rear to clear the larger distributor cap.
Old Nov 6, 2016 | 09:08 AM
redoldsman's Avatar
Proud Viet Nam Veteran
On my 72 I used a plastic spacer on top of the carb. It was so long ago I bought it at Supershops. I just looked and Summit has a bunch of them. Here is the link:
https://www.summitracing.com/int/sea...illocation=int
Old Nov 6, 2016 | 09:19 AM
That's a blast from the past!
Old Nov 6, 2016 | 09:28 AM
redoldsman's Avatar
We are probably dating ourselves Joe. I know it was about 23 years because I bought the Cutlass in 1993 and the HEI was one of the first things I changed on it. If I remember correctly, Supershops was a sponsor for Don Garlits.
Old Nov 6, 2016 | 09:32 AM
svnt442's Avatar
I used to work at 4 of the 5 stores in the Chicago area.
Old Nov 6, 2016 | 09:34 AM
svnt442's Avatar
Old Nov 6, 2016 | 09:36 AM
Eddie Hill, actually. Wynns was the perpetual Big Daddy sponsor.
SuperShops went out of business in 1998. I used them a lot when I lived in SOCal in the 1980s. Of course, we all had this poster:
svnt442's Avatar
Eddie Hill as well
Old Nov 6, 2016 | 09:39 AM
Originally Posted by svnt442
I had forgotten about that. Senility, obviously...
Old Nov 6, 2016 | 09:40 AM
svnt442's Avatar
Joe did you ever see the documentary about Eddie Hill where he talks about his drag boat accident where he hit the water face first as over 100 mph? His eyes were completely bloodshot for over 3 months I think and there was a point to where he thought they would never clear up.
Old Nov 6, 2016 | 09:43 AM
No, but I'd read the story in several publications.
Fortunately, the OP got his answer already, so I'm less concerned about getting this thread off the road, through the weeds, and nearly into a bridge abutment.
Old Nov 6, 2016 | 09:44 AM
svnt442's Avatar
no, but i'd read the story in several publications.
Fortunately, the op got his answer already, so i'm less concerned about getting this thread off the road, through the weeds, and nearly into a bridge abutment.
I don't care who ya are, that's funny right there!!
Old Nov 7, 2016 | 02:25 PM
BlackGold's Avatar
Eddie Hill was so much fun to watch; everyone loves the underdog. He always had the best engine explosions. I can still picture the one where his block split in half right down the middle.
Old Nov 7, 2016 | 02:41 PM
tru-blue 442's Avatar
Old School Olds
grm, pm sent. I have an off-set breather for a 4 bbl with the relief for HEI.
Old Nov 7, 2016 | 03:31 PM
ELY442's Avatar
I used a 48oz ball peen hammer to shaped it up
Old Nov 7, 2016 | 06:30 PM
I did the same thing in a different application.
Works great, and invisible when installed.
Old Nov 7, 2016 | 07:17 PM
steverw's Avatar
I still have the Mallory fuel pump on my Vette that i bought from Super Shops, several years before they closed. Perhaps i should buy a new one, just in case?
Old Nov 7, 2016 | 08:23 PM
The Super Shops in San Antonio for us was the equivalent of the Bass pro Shop for sportsman.
Old Nov 7, 2016 | 09:02 PM
don71's Avatar
same but different
This is so true, for the KC guys as well.
"like" this thread.
Harvey, like Randy said in post #2 a late air cleaner should work just fine for you...or a spacer. Some folks have modified their housing as well, if you like to fabricate things by cutting and welding...its been done.
Old Nov 8, 2016 | 07:29 AM
Arrowstorm's Avatar
Olds Wagonmaster
Samesies as some of the other guys.
HAMMER! Lol.
Old Jan 3, 2017 | 03:40 AM
Leadfoot's Avatar
...the factory air cleaner base looks to be a clearance issue. I'm sure it can be modified to work, or the entire base be raised, or a carb spacer, etc. what (other than a chrome air cleaner) have some of you guys done?
I'll lightly resurrect this thread, since I'm in a similar situation. I think I investigated all of the options, and in my mind, by far the neatest solution is a spacer between the carb and the air cleaner. For a 4 bbl, these spacers are readily available (5-1/8" dia.) from multiple sources. I believe the Cutlass Supreme should have a Quadrajet (didn't they all?)
For a 2-jet carb (3-1/16" dia.), I have not found a spacer made by anybody, anywhere, so I'm having to make one for my application.
Old Jan 3, 2017 | 05:28 AM
sammy's Avatar
Sammy70 455 Supreme
Adam, u still have this?
Old Jan 3, 2017 | 05:32 AM
Old School Olds
Hi Ted, yes I do.
Old Jan 3, 2017 | 05:35 AM
sammy's Avatar
Sammy70 455 Supreme
Are you willing to sell it to a great Canadian guy!...lol
Old Jan 3, 2017 | 05:41 AM
Old School Olds
No Problem! But shipping will suck as you know, I went ahead and bumped my thread for pics for ya.
Old Jan 3, 2017 | 08:37 AM
JohnnyBs68S's Avatar
I'm not positive about other years, but at least in '70 a 2-bbl 350 was a cost-saving option on the Cutlass Supreme. I used to have a '70 C/S 'vert and it had the 350-2bbl.
Old Jan 3, 2017 | 08:41 AM
RPO L65, a $33.70 credit option in 1970 and 71 (RPO L32, a $33.00 credit in 1972). Also, the L33 455 2bbl was used in the SX package for a while.
JOHNNYOLDS442
Nov 18, 2015 11:54 AM
joepenoso
Jun 4, 2014 01:56 PM
69CutlassAlex
Dec 2, 2011 08:01 AM
agtw31
Aug 23, 2009 04:02 PM
vette442
Jul 28, 2009 11:35 AM
