Molding Identification Needed
Old Apr 5, 2017 | 03:02 PM
scott_442's Avatar
I've got these two pieces of stainless that I'm pretty sure are the 2 vinyl top trim pieces for 70-72 fastback Cutlass but not 100% sure. the odd part is that one end is open and the other end has a slight angle and is closed like a terminating piece but I know there is a corner piece for each end. Both pieces also have a slight bow on one end and measure 28". Just looking for confirmation on what these really are. Thanks.
Old Apr 6, 2017 | 07:19 PM
tdhill01's Avatar
Let me check my trim and I'll let you know this weekend.
Old Apr 9, 2017 | 05:37 PM
tdhill01's Avatar
I checked my trim and I didn't find anything the length of your trim piece. I have drip rail trim that has the ends your describing but they are only a bit over 19" each. Maybe your trim is from a larger Olds vehicle?
Old Apr 10, 2017 | 05:19 AM
scott_442's Avatar
Not sure but thanks for checking ...so what is the correct length for the vinyl top pieces on a 70-72 Cutlass?
Old Apr 10, 2017 | 06:33 AM
oldspackrat's Avatar
If one end is closed, it is very likely for the '72 Cutlass Supreme. That trim piece ended at the bottom of the drip rail molding right behind the quarter glass, where the S had a chromed pot metal V-ish shaped piece that was inserted into the end of the C pillar piece.
I tried to copy & paste pix below but my skills are lacking in this area.....
https://www.google.com/url?sa=i&rct=...91917315824974
https://encrypted-tbn2.gstatic.com/i...wKMizhS78y9wkn
Old Apr 10, 2017 | 10:00 AM
NHolds's Avatar
Ya... Supreme pcs.
70W30Jim
Feb 12, 2014 04:01 PM
Dananoak
Jul 8, 2013 06:19 AM
cigarguy
Jan 7, 2013 11:03 PM
bigjeffscv
Jul 7, 2012 08:58 PM
RDG
Feb 8, 2010 10:25 AM
