Molding identification
These moldings fit along the bottom lip of the trunk lid. The small ones go on the ends above the tail lights. They are attached so that the screws are installed on the inner portion of the trunk lid. It's been a while since I worked on a 70-72 so I'm not sure if they would be the same for all 3 years or not.
Do you mean the hood "tooth" that hangs down from the front/center or do you mean the 2 chrome trim pieces that mount on the hood and sit over the tops of the grills?
Both are repro'd
