stock tac
Old Aug 12, 2016 | 08:08 AM
jwr7042's Avatar
stock tac
1970 442 rally pack gauges. will the tac hook up to an msd coil without burning it up?
Old Aug 12, 2016 | 08:14 AM
It will work on some, you just need to give it a try and verify accuracy.
Old Aug 12, 2016 | 09:17 AM
Does this MSD coil hook up like the stock one? If so, no problem.
Old Aug 12, 2016 | 11:25 AM
Its usually not the coil itself that throws it off, its the multispark system itself.
Old Aug 12, 2016 | 12:21 PM
ronskal's Avatar
Did not work on mine, either hooked up direct to the coil or to the MSD Tach out wire on the MSD Box. I need to get the signal adapter from MSD as I suspect you will also.
Like Oldcutlass said it is the MSD signal is too much for the old tach.
Old Aug 12, 2016 | 12:30 PM
So once again we see the importance of asking the right question.
What is an "MSD coil"? Is the OP simply talking about an aftermarket coil with a stock distributor, or is this a complete MSD ignition system? If the latter, which one?
One option, of course, is to read the instructions. If the OP is actually talking about an MSD 6 box, it has a dedicated TACH output, as shown in the wiring diagram. If the OP is talking about a different MSD system, it's impossible to provide a useful response without specifics. The mind reading thing still isn't working.
See page two of these instructions:
https://www.jegs.com/InstallationIns...1/121-6420.pdf
Old Aug 12, 2016 | 05:54 PM
tomhartrides's Avatar
Joe, I love your comment. 100% agree. I also wish people thought thru the use of the title of their question. Like "need help with Olds". Just a rant from a person tired of clicking thru to questions that really have no immediate answer.
Old Aug 12, 2016 | 10:16 PM
z11375ss's Avatar
Senior Moment Member
I agree. Had to do this with my 69 W-30 car. The 68 I have now has an MSD Billet in it so no muss, no fuss.
steve walker
Nov 19, 2014 07:47 PM
nelsontj
Feb 22, 2009 07:10 PM
cmurray
Feb 15, 2009 10:03 PM
buckeye_hunter
Oct 19, 2008 09:50 AM
gdam
Mar 10, 2008 05:40 PM
