Tic Toc Tac Conversion
Old Feb 12, 2009 | 06:16 PM
nelsontj's Avatar
Question Tic Toc Tac Conversion
I am putting in a rally pack tic toc tac, replacing the warning light gauges. I'm a little confused about the tach/clock wiring. My aftermarket tachometer had four wires: ground, 12 volt power, light and coil to tach connection. Now, with the rally pack tach/clock: terminal for clock, terminal for light, terminal for coil to tach and ground, of course is housing to dash metal to metal connection. Shouldn't there be a 12 volt power connection, or am I misunderstanding something?
Old Feb 12, 2009 | 06:51 PM
Lady72nRob71's Avatar
Welcome Nelson! What year is your olds?
I did this conversion over a year ago.
The tach gets its power from the clock power terminal, which is constant 12V. This is the thick orange wire (in 72 at least.)
The gauge cluster has totally differerent witing configuration than the idiot light set. I think there is a good wiring chart at 442.com if you do not have the chassis service manual.
Let us know if you need any other help!
Old Feb 13, 2009 | 09:31 AM
Oldsguy's Avatar
Past Administrator
Yes I agree with Rob, you power is going to be from the clock and it should be orange. I have found that Olds used that color for quite a while in the seventies, perhaps longer. Welcome to our site.
Old Feb 13, 2009 | 09:58 AM
One other thing, Nelson - are these repro units or factory?
If repro, visit my flickr photo site in my signature and see how you ~may~ need to open them up and paint the interior for better night illumination.
Old Feb 14, 2009 | 03:01 AM
Yellowstatue's Avatar
Smile Rally Pac
The factory used a brown wire for the tach feed from the coil right in the main harness if it originally came with a tach...The guages use the same wires but in a different order than idiot lights...it's in the shop manual...you have to unlock the pins in the connector and switch them around...
Old Feb 14, 2009 | 04:33 AM
My442's Avatar
Here you go
Old Feb 17, 2009 | 06:38 PM
nelsontj's Avatar
Thanks for the help and welcome. I would guess the ignition coil to tack shielded cable loop goes to any convenient ground. Right? Thanks again!
Old Feb 18, 2009 | 05:45 AM
If you use the correct shielded cable, then the shield part of the cable goes to ground. The inner wire goes from the tach to the disty side of the coil. When I did mine, I cheaped out and used a regular piece of unshielded wire; no issues as of yet...
Old Feb 18, 2009 | 02:16 PM
nelsontj's Avatar
You members have been extremely helpful. I'm confident I can get it done when I pull the car out of hibernation in the spring. By the way, the question was asked as far as what I have. I have a 1970 442 that I've had since 1974. If I had the opportunity of buying it new I would have ordered the gauge package with it, but I was not that fortunate. I'm just happy I could get it 4 years after its assembly date. Thanks again!
Old Feb 22, 2009 | 07:10 PM
oldoldss's Avatar
Another look
The conversion process was in Journey With Olds (the Oldsmobile Club of America newsletter) probably 6 or 8 years ago. It really didn't seem that hard.
67442nut
Oct 28, 2010 10:45 PM
ctreutel
Aug 20, 2009 03:58 PM
cmurray
Feb 15, 2009 10:03 PM
buckeye_hunter
Oct 19, 2008 09:50 AM
gdam
Mar 10, 2008 05:40 PM
