10 OHM Resistance Wire Question
I've been working on fixing my dash wiring harness and in the process came across a 10 ohm resistance wire. According to the wiring diagram, this wire runs from the ignition connector on the column to the external voltage regulator. Is this wire needed if I'm running an alternator with an internal regulator and electronic ignition?
Also if you could school me on what exactly it's function was I'd really appreciate it.
Demond's Muscle Car
November 30th, 2014 05:17 PM
