Shift indicator removal on the cosole
OK, twenty questions....
Regular shifter or dual gate? The indicator for the regular shifter is part of the woodgrain applique panel, which is stuck to the console with double stick tape. Remove the console and carefully pry the panel off from the underside. The dual gate panel is bolted on, also from the underside.
rothlane'68
Mar 31, 2016 10:48 AM
