Ram air
Old August 31st, 2017, 01:57 PM
fshilling's Avatar
Ram air
Hi. I am installing a OAI setup from scratch on my 1969 442. I bought the kit from The parts place. Of course they dont have installation instructions. Can anyone help me?
Fred
fshilling is offline
Old September 1st, 2017, 05:13 AM
Fred
All the info is in here:
joe_padavano is offline
Old September 19th, 2017, 11:03 AM
JohnnyBs68S's Avatar
I'm in the same boat.......
Thanks for the info Joe. I have a .PDF version for my '68, but the page / figure for the OAI scoop installation seems to be missing. Seems that somewhere in the distant past I stumbled across some templates or measurements showing exactly where to cut the 4" holes for the scoops. But I can't seem to find it now. In the mean time, I'm using any reference photos I can find.
I'm adding the '68 OAI setup (also from TPP) to my 350-2bbl (it WILL be a 4-bbl in the not too distant future, but for now I'm using a carb adapter to fit it to my 2 bbl........go ahead and laugh). Any how, discovered I needed a new PCV vent tube from the air cleaner filter to the valve cover since the old one "twists" the wrong way. Now that I have the correct one, discovered that the air cleaner is sitting ~1" higher apparently because the tube is too short. I'll rig something for that until I get the engine rebuilt w/ a 4-bbl.
What HAS surprised me is, I purchased a new air cleaner "pie tin" since it is larger than the one used on the 2-bbl air cleaner. However, the chrome retainer from my 2 bbl is ~ 1" too small in diameter to retain the larger 4-bbl pie-tin on the 4-bbl dual snorkel air cleaner. I've shopped around and can find only one size retainer. Who makes a larger retainer for the 4-bbl pie tins?
JohnnyBs68S is offline
Old September 20th, 2017, 03:38 AM
rob1960's Avatar
Fusick has them pt# FPR680 for $24
rob1960 is offline
Old September 20th, 2017, 06:50 AM
Aye, description:
Air Filter Plate Chrome Retainer, 66-70 Toronado, 1968 OldsChrome plated retainer used to hold down the aluminum air cleaner top plates on 1968 Oldsmobile models and 1966-70 Toronado.
This implies that it fits ALL '68 Olds, including a 2 bbl 350 air cleaner. Well, I HAVE one of those already, and it is too small to clamp down the 4-bbl pie tin on a 4-bbl air cleaner. Without dimensions in the product description, I'm hesitant to spend money on something that might not work.
UNLESS, there actually ARE two different sizes of chrome hold-downs, and NOBODY repros the smaller one for the 2-bbl air cleaners. However, Fusicks also sells the 2-bbl pie tin, why would they not also carry a hold-down for that if it is, in fact, smaller than the 4-bbl hold-down? It doesn't make any sense.
If someone DOES have a FPR680, what is the diameter of it?
Maybe I'll just email Fusicks and ask.
Old September 20th, 2017, 10:08 AM
That was quick:
Hi John,
The diameter of the FPR680 is 4 ½”.
Thanks,
Kevin
Fusick Automotive Products
I'm pretty sure the 2-bbl hold down measured only ~ 3.25". Once I confirm I'll be ordering the FPR680.
Old September 20th, 2017, 07:13 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Cool but got you beat. I have a forced air Olds 260.
olds 307 and 403 is offline
Old March 19th, 2019, 05:38 PM
O'smobile
Orlando 1's Avatar
I'm hearing that the 68 and 69 under bumper scoops are different? The Fusick photos show a size change between years. Apparently the 69 version is better? Anyone have dimensions? I'd like to add OAI to my car and I would like the better design of the two.
Orlando 1 is offline
Old March 19th, 2019, 07:28 PM
Yellowstatue's Avatar
'68 scoops are about 12 inches wide and '69 scoops are about 8 inches wide approximately but otherwise fit in the same location.
Yellowstatue is offline
Old March 20th, 2019, 03:55 AM
The 69 scoops are about a 1/2" taller than the 68 too (guessing 2" on the 68s, 2.5" on the 69s). 24 in^2 (68) vs. 20 in^2 (69). Maybe the '69s are a full inch taller, making them also 24 in^2. Hard to claim one design is more efficient or "better" than the other IMO.
Old March 20th, 2019, 08:31 AM
OLDSter Ralph's Avatar
Johnny, I am sure you are pretty close. I would think the size and CFM flow is comparable using the '69 scoops.
OP, use the scoops that are correct for your year.
..........Just my two cents worth.
OLDSter Ralph is offline
Old March 20th, 2019, 07:46 PM
I sold my '69 scoops so I can't compare them to my '68s.
Old March 23rd, 2019, 04:50 PM
O'smobile
Orlando 1's Avatar
My original thought was to use the '68 scoops for correctness. I guess there was a post about water getting sucked in that got me thinking.
Old March 25th, 2019, 04:06 PM
O'smobile
Orlando 1's Avatar
Fender Skirt hole (passenger only)
Fred
I saw this for sale and remembered this post. Passenger side it seems.
oz71w30
April 22nd, 2017 05:57 AM
68442
November 17th, 2016 03:57 AM
stlbluesbrother
February 7th, 2013 10:16 AM
benji94
September 13th, 2012 10:24 AM
Jonb442
February 12th, 2010 02:30 PM
Quick Reply: Ram air
