73 Cutlass cowl tag
Old Sep 27, 2017 | 09:22 PM
Andrew83's Avatar
73 Cutlass cowl tag
Looking for advice to decode the cowl tag on my 73 Cutlass 442 Vin tells me it was a 350 Lansaing coup. I will attach a photo cause I'm getting conflicting information from the internet and I know you guys will be able to decode this.
Old Sep 27, 2017 | 09:42 PM
texxas's Avatar
The M20 denotes manual transmission, AN7 is swivel buckets, D55 is front compartment console. 26 26 is Zodiac blue poly, upper and lower body. I'm sure others will help with the rest of the codes.
You should list your car in the 73-77 registry and it will show you other options available and the codes for each.
https://www.v8cars.hu/73-77cutlassregistry/
Old Sep 27, 2017 | 09:46 PM
Andrew83's Avatar
Thank you. I've been trying to discover its original identity since I bring the car home. The vin only tells you so much. Some people were trying to tell me it wasn't a 442. But everything I've discovered tells me it is. Front rear sway bars, heavy cast decals, ect. Thanks for the info
Old Sep 27, 2017 | 10:01 PM
Andrew83's Avatar
Do you know if anything on the cowl tag indicates the 442 package on this year?
Old Sep 28, 2017 | 09:24 AM
jwsolds's Avatar
Nothing on cowl will say it has 442 option, only paperwork can varify that. But you hv a rare desirable 4spd car never the less.
Old Sep 30, 2017 | 02:46 PM
aretubj's Avatar
Although, a lot of 1973 4spd cars are coming out of the wood work lately.
442 was an appearance package only, no different than ordering the interior light package.
Joe
Old Sep 30, 2017 | 03:06 PM
Andrew83's Avatar
Ok do you know the specific differences between the Cutlass S and 442 package? I know there is not much changes but I'm trying to figure out what is different.
Old Sep 30, 2017 | 06:25 PM
oldsmobiledave's Avatar
Fyi
Cutlass S is a model. The W-29 442 option was just an appearance package for the Cutlass or the Cutlass S.
Old Sep 30, 2017 | 06:28 PM
Andrew83's Avatar
Hey thanks oldsmobiledave I understand the 442 was a package. I've been trying to figure out what that package upgrade included.
Old Sep 30, 2017 | 06:44 PM
W-29 1873
Look at the bottom of the second page.
Clipperet
Mar 22, 2025 05:45 AM
Mikes65
Apr 26, 2012 10:21 AM
danreckner
Apr 10, 2012 08:54 AM
70455cutt
Mar 9, 2009 04:49 PM
Mr. King
Jan 14, 2007 07:47 PM
