Bolts and Fasteners 68 Cutlass / 442
Old May 1, 2018 | 08:33 PM
servexcell's Avatar
Where to find Jclips and nuts for restoration . I found GM part numbers in Assembly Manuel , checked with AMK supplier they do not have.
Any sugestions
thanks Bruce
Old May 3, 2018 | 04:56 AM
allyolds68's Avatar
Any sugestions
thanks Bruce
Bruce,
Can you please post a picture of what you're looking for or at least say what page of the assembly manual they are on
Old May 3, 2018 | 03:24 PM
CRUZN 66's Avatar
Olds Fever
AUVECO is one of the biggest suppliers of automotive hardware... Easy to cross reference GM part numbers... Fastenal is also another good source...
Here is an AUVECO link: https://www.auveco.com/
Old May 8, 2018 | 09:26 PM
servexcell's Avatar
Pages 113 , 120 ,121
Part no. 392762 , 391359 nuts
68 cutlass
Old May 8, 2018 | 09:36 PM
servexcell's Avatar
Page 141 part no.397639 nut 387730 nut
Old May 9, 2018 | 08:10 AM
lemoldsnut's Avatar
The hardware section of your local Lowe's has a pretty good selection as well.
Old May 9, 2018 | 08:30 AM
allyolds68's Avatar
68 cutlass
The page numbers aren't very helpful without the section number.
Old May 9, 2018 | 10:12 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Many restoration vendors offer hardware, fasteners and trim clips etc...Google it.
Stay away from all the big home improvement and auto parts retailers(sorry lem)... it's all chineasium grade -10 junk. It will sheer, rust, gall, strip and simply not perform well even their SS fasteners are grade 0 junk.
Another avenue is used. Several guys here in the classified section part these cars. Nothing like OEM GM Original hardware.
The trim clips are available at a good automotive body shop an paint supply house. But you need to bring an example to match it up. This is where I found the common stuff for my 68s. Fusick, Year One etc...had the specific 68 stuff. Check out Inline Tube as well. They offer a ton of quality hardware.
Old May 9, 2018 | 02:24 PM
servexcell's Avatar
Mike section 11 of Assembly Manuel , Thanks
Thanks as well droldsmorland I will check with them although I do not think they have them
Bruce
Old May 10, 2018 | 07:16 AM
Bruce,
What Mike said. J clips could be several things. I little cleared description and location of these fasteners will help us zero in.
Old May 10, 2018 | 07:41 AM
allyolds68's Avatar
68 cutlass
I still can't find where 392762 is.
391359 are common and used everywhere. I assume you have some old rusty ones that you could post a pic of and you can find used ones
397639 are the inner fender clip nuts. I'm sure you can find nice used ones of those too
387730 is harder to find because it sits in an area that tends to really rust.
I really didn't worry about fasteners being perfectly correct so I just found the closest match's for my stuff at Auveco
Scott Winn probably has hundreds of these fasteners
servexcell
Nov 24, 2017 08:07 AM
stanzaschance
Jul 28, 2015 06:38 AM
nolabigdawg
Oct 25, 2014 11:50 AM
Drivetrain/Differentials
Nov 14, 2008 12:00 AM
Oct 20, 2008 07:56 PM
