convertible top fluid
Old Jul 11, 2017 | 01:21 PM
x55racer's Avatar
How do I add fluid to the convertible top pump on a "71 Cutlass Supreme?
Old Jul 11, 2017 | 03:08 PM
Locate the pump in the trunk behind the back seat. Remove the rubber plug in the end of the reservoir. Fill.
Old Jul 11, 2017 | 03:26 PM
lshlsh2's Avatar
71 cutlass convertible
A turkey baster works for filling the pump. I would buy a new one, using your wife's out of the kitchen could get you into a little trouble.
Old Jul 11, 2017 | 04:26 PM
Tedd Thompson's Avatar
Or a ketchup/ mustard bottle as found at your local diner with a 2 foot length of 1/4" clear plastic tubing and a bunch of towels stuffed around the motor area so when you over fill it you won't make a mess.(don't ask me how I know).... Tedd
Old Jul 11, 2017 | 06:25 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Good tips there Tedd. It is a messy job. I don't think anybody mentioned to use ATF to fill the pump. DO NOT use brake fluid since it will eat paint if it gets on it.
Old Jul 12, 2017 | 07:14 AM
And if it has brake fluid in it now you gotta get it all out before you add ATF. I doubt that they were using brake fluid as late as 71 but check it out or you will have a mess on your hands.... Tedd
Old Jul 18, 2017 | 07:47 PM
x55racer's Avatar
Thanks for the info, guys. I knew about the turkey baster and using ATF, I just didn't know where the fluid went in. And I'll be sure to buy a new one! Don't want to be sleeping in the garage with my car.
Old Jul 18, 2017 | 08:32 PM
m371961's Avatar
I dunno, if I ever finish my seats, I might do just that.
Old Apr 9, 2020 | 10:24 PM
RATCHETMASTER's Avatar
"I reckon so!"
Yep.
Old Apr 10, 2020 | 04:19 AM
When I reupholstered my interior I found my left cylinder was leaking all over on the floor. One thing led to another and next thing you know another project! Anyway if it just got low you may want to check out why before you have a big mess.
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
MudEye
Dec 21, 2011 10:52 AM
squirell
Jun 30, 2009 08:56 AM
cfair
Jun 8, 2009 12:37 AM
70redvert
Dec 22, 2007 04:53 PM
