Muncie and Chevy 12 Bolt Lube--Interchangeable??
Old Jun 5, 2017 | 08:01 AM
David DeCan's Avatar
Considering using two different lubes on my 68 Muncie and 68 Chevy 12 bolt.
Sta-Lube 85W-90 GL4
or
GM ACDelco 80W-90 GL4 with GM ACDelco No Slip Additive.
Can I use the same lube for both?
Old Jun 5, 2017 | 02:28 PM
My442's Avatar
Use the Sta Lube.
The additives in the other oil may effect shifting.
Old Jun 5, 2017 | 02:50 PM
Use the sta-lube in both and the separate posi lube in the rear.
moys71
Feb 16, 2021 08:22 PM
David DeCan
Drivetrain/Differentials
May 21, 2017 09:57 PM
72delta88
Non-Olds Engines
Oct 28, 2016 01:02 PM
boese1978
Feb 14, 2014 10:56 AM
Lady72nRob71
Mar 12, 2008 05:31 AM
