big block chevy and muncie 4 speed swap
I moved your thread to the non-olds powered section. I'm not sure if you can use motor mount frame brackets from a Chevrolet Impala, Biscayne, Bel Air, Caprice, Kingswood, Townsman, Brookwood or possibly have to fab your own. The rest is minor electrical, fuel line mods, and possible ebrake cable and driveshaft mods due to trans length.
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
the SBC/BBC motor mount is the same and Im pretty sure the SBO/BBO motor mount is the same, but they are SLIGHTLY different, slightly as in wrong mount wont fit the wrong engine, but the holes in the chassis should be there, drill bolt or weld. I would hepl transplant the same built 350 or 454 into d-cars and lesa's etc year after year for the demos and it was not that hard. Im a little wishy washy on 72 even tho I know intrinsically it should be spot on with the 75/76 models I have worked on
ybicutty
Oct 12, 2012 05:11 AM
ccnclassicoldsmobile
Jul 26, 2012 11:49 AM
