Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
big block chevy and muncie 4 speed swap
Old Oct 27, 2016 | 03:23 PM
72delta88's Avatar
ok I know this may start a war but I'm swapping my 72 delta 88 from a 350/ th400 sbo to a 632 4 speed bbc I need engine mounting advice any ideas
Old Oct 27, 2016 | 04:06 PM
I moved your thread to the non-olds powered section. I'm not sure if you can use motor mount frame brackets from a Chevrolet Impala, Biscayne, Bel Air, Caprice, Kingswood, Townsman, Brookwood or possibly have to fab your own. The rest is minor electrical, fuel line mods, and possible ebrake cable and driveshaft mods due to trans length.
Old Oct 27, 2016 | 04:08 PM
72delta88's Avatar
thanks for movin it I'm checkin it to see I love my 350 rocket but finding parts to hop it up sucks and 455s are few an far between
Old Oct 27, 2016 | 04:34 PM
72delta88's Avatar
it looks like I'm gonna have to get universal bbc/sbc mounts and mock it up in the car before I weld them in how much do you think the 350r is worth
Old Oct 27, 2016 | 04:35 PM
I forgot to ad that the clutch pedal assy may be a challenge but not impossible with todays hydraulics.
Old Oct 27, 2016 | 04:39 PM
72delta88's Avatar
I decided to go with a full manual 700r4 so I wont need the clutch I'm still trying to figure out the mount situation for the engine
Old Oct 27, 2016 | 04:41 PM
Speedway has hot rod mounts that you can weld in if there are no frame brackets that cross to the Delta.
Old Oct 27, 2016 | 04:44 PM
72delta88's Avatar
do you know any one who has a project they need an engine an trans for I'm gonna sell the 350/th400 combo for 1000
Old Oct 27, 2016 | 04:48 PM
Put it in the parts for sale section, someone will probably take it.
Old Oct 27, 2016 | 04:50 PM
72delta88's Avatar
since the car is my daily I gave up on keeping it original I'm kinda missing my overdrive and my sbc ease of finding parts
Old Oct 27, 2016 | 07:29 PM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
the SBC/BBC motor mount is the same and Im pretty sure the SBO/BBO motor mount is the same, but they are SLIGHTLY different, slightly as in wrong mount wont fit the wrong engine, but the holes in the chassis should be there, drill bolt or weld. I would hepl transplant the same built 350 or 454 into d-cars and lesa's etc year after year for the demos and it was not that hard. Im a little wishy washy on 72 even tho I know intrinsically it should be spot on with the 75/76 models I have worked on
Old Oct 28, 2016 | 01:02 PM
72delta88's Avatar
have u ever ha issues with it back firing into the intake on a sbo do to a bad exhaust choke
bspaulding
Sep 3, 2016 04:15 PM
Octania
Apr 7, 2016 02:51 PM
GAOldsman
Feb 23, 2013 12:55 PM
ybicutty
Oct 12, 2012 05:11 AM
ccnclassicoldsmobile
Jul 26, 2012 11:49 AM
