Driveline length 70 Cutlass 350/TH350--swap to Muncie and Chevy 12 bolt
Old May 18, 2017 | 10:04 AM
David DeCan's Avatar
Swapping a Muncie 4 speed in my 70 cutlass. Also swapping in a true Chevy 12 bolt posi differential.
Purchased conversion u-joint so the yoke on the Chevy 12 bolt will stay the same.
I am told my driveline transmission yoke is the same for a TH350 and a Muncie.
My QUESTION:
Is the driveline length going to fit?
I am also told the TH350 and the Muncie are the same length. What about the Chevy 12 bolt with Chevy 12 bolt yoke swapped in place of the "O" type Oldsmobile differential? Driveline length same?
Thank you.
Old May 19, 2017 | 05:21 AM
monzaz's Avatar
driveshaft length munice to 350th to 1 bolt O to 12 bolt chevy
Yes it should all swap over with just a u-joint swap to 372 moog conversion joint also known as chevy to BOP u-joint.
THAT is if your muncie is the same length as a 350th trans.
J D RAce
Jim
Old May 19, 2017 | 09:36 AM
Thanks JD.
The Chevy 12 bolt is a 68. Is it going to use "U-Bolts" with nuts and lock washers or straps with screw in bolts?
Thank you.
FYI to others--I am finding the fasteners needed from Supercars, Part Place, In Line Tube. Thanks.
Old May 21, 2017 | 09:57 PM
monzaz's Avatar
Originally Posted by David DeCan
Thanks JD.
Thank you.
If it is a true 68 all original it will take u-bolts and nuts...1970-1972 usually the 10 and 12 bolt chevys changed to a beefier yoke and it had 4 fine thread bolts and 2 straps. The bolts were the same thread 24 count as the 10 bolt 8.5 but the straps are for the 1.063 caps not the 1.125 mechanics 3R caps....
you will physically have to check your 12 bolt to which one it has...it could have a BOP yoke also if it came from a Canadian B O P a-body....
send pics will ID for you.
70sgeek
Nov 7, 2016 12:14 PM
72delta88
Non-Olds Engines
Oct 28, 2016 01:02 PM
Rhodetd
Aug 8, 2013 07:19 AM
radcar
Drivetrain/Differentials
Mar 5, 2013 03:57 PM
ilde
Aug 17, 2012 11:07 AM
