Question on mechanics fuel pump and fuel lines
Old March 21st, 2018, 06:10 AM
Joe Ralph
72442455's Avatar
Question on mechanical fuel pump and fuel lines
Hello all,
I have a 72 cutlass convertible A body with a 68 455 in it - I have had bad luck with electric pumps and want to put a mechanical pump in it. The parts store wanted to sell me a three hose adapter pump - after a little reading it seems that there is an fuel inlet and outlet + a return fuel line for the pump? My car has two steel lines running down the frame - I assume one is the primary fuel line - but I believe the other is the carbon canister vapor line? So no fuel return line? If I only need a two line pump how do I determine what pump will fit / work? - also ... when Installing the pump - it currently has just a metal plate covering the hole for the fuel pump - when I pull that will oil pour out? (Newbie question I know...) so the seal on pump will prevent oil leaking? Any help / insight is appreciated - thanks in advance for all reply’s!
Joe
72442455 is offline
Old March 21st, 2018, 08:32 AM
4speed455's Avatar
The second steel line in your frame is the return line. The vapor canister comes off the tank. The third line on the fuel pump would go to your carb. And no oil should come out of the fuel pump block off plate when removed unless the motor was running.
4speed455 is offline
Old March 21st, 2018, 09:44 AM
Joe Ralph
72442455's Avatar
few questions - second steel line is *fuel* return line? Vapor canister comes of the *gas* tank? If so what kind of line is it if not steel? And third line on fuel pump goes to the fuel inlet on carb - then I assume 1st is primary from tank and second is fuel return? - thanks for your time!
Joe
72442455 is offline
Old March 21st, 2018, 12:28 PM
Joe Ralph
72442455's Avatar
72442455 is offline
Joe Ralph
72442455's Avatar
Hard to see what’s going on I’m the cm 🙁
72442455 is offline
Old March 21st, 2018, 12:53 PM
Sorry, this is not correct. For a 1972 Cutlass, the 3/8 line is the feed line to the pump. The smaller line is the vent line to the charcoal canister that mounts behind the passenger side headlights. If the car had fuel return, it would have had THREE steel lines on the frame rail. If you asked for a pump for a 455, you got the three line pump. Get a pump for a 350 with two lines (one inlet, one outlet).
joe_padavano is offline
Old March 21st, 2018, 01:19 PM
Old School Olds
tru-blue 442's Avatar
When you pull the plate make sure you have a fuel pump eccentric bolted to
the cam gear as shown here. You can see where the f/p arm rests on it.
tru-blue 442 is offline
Old March 21st, 2018, 01:37 PM
Joe Ralph
72442455's Avatar
since it’s a 1968 455 out of a toronado will a 72 350 mechanical fuel pump bolt right up no problem?
72442455 is offline
Old March 21st, 2018, 01:41 PM
Joe Ralph
72442455's Avatar
thanks Tru-Blue! First time doing a mechanical fuel pump - that helps tons to see what’s going on! ~ Joe
72442455 is offline
Old March 21st, 2018, 02:00 PM
Old School Olds
I also helps to roll the engine over where the eccentric is at it's lowest point
also as shown. This helps put less pressure on the pump arm when attaching
the bolt and nut if it has the correct bolt on top for the nut. There will be some resistance but that is normal.
Old March 21st, 2018, 02:43 PM
Joe Ralph
72442455's Avatar
thanks again! Are the pumps for 350s and 455s from 68 - 72 pretty much universal? No issues bolting them up?
72442455 is offline
Old March 21st, 2018, 02:45 PM
Old School Olds
They are pretty much the same, differences are a/c vs no a/c.
Old March 21st, 2018, 02:47 PM
Joe Ralph
72442455's Avatar
thanks!
72442455 is offline
Old March 21st, 2018, 03:24 PM
Old School Olds
Don't get one for a Toro though. I think they are taller and may get in the way of the a/c brackets, not real sure.
Old March 22nd, 2018, 02:55 AM
Be sure you know that unlike Chevy motors, Oldsmobile pumps install with the pump body "up".
Old March 22nd, 2018, 01:14 PM
Joe Ralph
72442455's Avatar
so both the fuel lines would connect on the top side? Is that correct Joe?
72442455 is offline
Old March 22nd, 2018, 01:33 PM
Joe Ralph
72442455's Avatar
Actually that was a dumb question - sorry to waste your time - I was able to look at some images online to see what I needed - that an the inside view tru-blue attached and it’s pretty obvious - thanks all for your help this is EXACTLY what I needed! ~ Joe R.
72442455 is offline
Daniel828
November 23rd, 2017 04:04 PM
wyteon
January 24th, 2015 03:24 PM
507OLDS
May 5th, 2014 12:53 PM
DEEZPAZ
May 14th, 2011 09:30 PM
gearheads78
November 16th, 2008 09:58 AM
Quick Reply: Question on mechanics fuel pump and fuel lines
