Alignment
Old Jan 5, 2018 | 12:06 PM
My2nd 69 442's Avatar
Alignment
I'm gonna have my 69 442 (base) re-aligned next week and I wanyed to check with you folks to see if the numbers in the CSM are still the best settings to shoot for or if it's better to go with different settings.
The suspension is all stock with new ball joints and sway bay bushings. Nothing else has been changed to the best of my knowledge.
Thanks for any help .
Old Jan 5, 2018 | 12:39 PM
One of the biggest handling differences from the 1960s to modern cars is the fact that new cars have much more caster angle in the alignment. The factory caster setting for your 69 is somewhere around -1/4 deg to +1/2 deg. This was done to allow a light steering effort, especially with manual steering. Modern cars have closer to 3-4 deg of positive caster angle, which greatly improves tracking and steering feel at speed but increases steering force. Of course, since all new cars have power steering, that's a non-issue. Have the alignment shop crank in as much caster angle as the adjustment in the car will allow. I doubt you'll be able to get to 3 degrees, but anything over 1.5 or 2 degrees will be a phenomenal difference.
Of course, this assumes your shop's lawyers will allow them to align the car to something other than the factory specs.
Old Jan 5, 2018 | 12:45 PM
Thanks for the info Joe.
I kinda thought that may be the case as the added caster made a major difference with my 67 Camaro.
I don't believe that I will have any problems with the GM shop as my son is the shop manager.
Old Jan 21, 2018 | 01:42 PM
W31Andrew's Avatar
You might have already done the alignment, but here are some specs for reference.
Old Jan 21, 2018 | 02:17 PM
The whole point of this thread was that the OP was asking about NOT using the factory specs for alignment, as discussed above. The factory's negative caster is why these cars don't have the steering feel of new cars.
Old Jan 21, 2018 | 04:21 PM
dragline's Avatar
I'm new to this forum. Question; will I be bullied by joe also if I submit something useful like W31andrew? It was nice of him to take the time to look and post the base line specs. I hope this isn't another website where trolls bully sincere members trying to help.
Old Jan 21, 2018 | 04:24 PM
W31Andrew's Avatar
I'm new as well. Just trying to be helpful. Plus I figured my post may be helpful for others when searching for alignment specs in the future.
I hope this isn't common practice as well.
Old Jan 21, 2018 | 05:04 PM
Gary M's Avatar
Joe is a moderator on this site and has a wealth of knowledge. I would not look at it as bullying, he was keeping the thread on track. Stick around because you'll see bullying rarely happens here. Thanks for your efforts to help and welcome to CO.
Old Jan 22, 2018 | 06:18 AM
CDNW30's Avatar
From the chart above, it shows all the other GM A-bodies ( buick, chevelle, Pontiac,) with positive camber and Olds with negative camber. I wonder why this was done, since most parts are the same.
Old Jan 22, 2018 | 07:41 AM
I noticed that also. Keep in mind that each GM division tuned suspension and road feel separately, which is why each version of the A-body had unique springs, shocks, sway bars, tires, etc.
Old Jan 22, 2018 | 10:33 AM
m371961's Avatar
Sometimes Joe can strike new members that way, (he did me also), but you will see his knowledge and helpfulness is fantastic and he makes this site great. He is just very direct and it is not personal. I have worked with and learned a lot from engineers that tend to be this way.
Old Jan 22, 2018 | 04:14 PM
Only if you let yourself be bullied (and actually think what Joe posted was bullying ). It's the internet, not the real world where you may not have the option of walking away.
Old Jan 22, 2018 | 05:03 PM
I certainly appreciate all replies to my post.
Just a point I would like to make: I appreciate All info that Joe Padavano provides and strongly fill that he has more experience than most here and bad mouthing of Joe is unwanted. Joe on many occasions has freely given me the benefit of his vast experience and all is appreciated.
I would suggest if you happen to disagree to his advice then don't heed it, but otherwise shut the F up! No one is bullied that has the good sense to understand what he is trying to tell someone.
Old Jan 22, 2018 | 07:20 PM
Gary M's Avatar
Dragline ran this thread "into the weeds"
"I hope this isn't another website where trolls bully sincere members trying to help."
I've heard that if you have trouble with one person it could be them but if you have trouble with multiple people it's likely your the one with the problem. Could be dragline is misinterpreting people's responses as criticism or bullying on other forums too BUT the Troll here is not Joe.
​​​​​​​W31 Andrew tried to help and seemed civil about Joe getting the thread back on track. My last post was thanking and welcoming him.
Back to the original subject,
Let us know how the alignment goes. Good luck.
4Forty2
Apr 29, 2009 09:41 AM
ChrisM
Sep 3, 2008 09:26 AM
60Olds98
Ninety-Eight
Aug 22, 2008 05:30 PM
todd66442
Tech Editor's Desk
Aug 12, 2008 07:43 PM
projectheaven
Jan 26, 2008 05:01 PM
