alignment
Old Jan 26, 2008 | 03:50 PM
projectheaven's Avatar
alignment
Hello,
I have what's called toe in with my front wheels.I heard that I can place shims between the upper a arms to adjust this.Does anybody know if this is correct? Or at least know the correct way to do it?
Old Jan 26, 2008 | 04:51 PM
rocketraider's Avatar
Oldsdruid
Toe is adjusted with the tierod ends. You need some toe-in because as the car travels forward, the front wheels will bow outward on the spindle's axis and cause 1) squirrelly handling and 2) rapid and excessive tire wear if toe is not set correctly.
Caster and camber are adjusted by shimming the upper A-arms, to angle the top of the wheel in or out from centerline. I suggest you take the car to a good front-end alignment shop if you're unsure about it. Preferably one that has some experience with dubs, since with bigger wheels/tires, factory specs are probably not even relevant.
Old Jan 26, 2008 | 05:01 PM
That makes a ton of sense.I think I'll take it to a alignment shop to be on the safe side.Thank you for your help.
tim72
Dec 21, 2009 04:18 AM
4Forty2
Apr 29, 2009 09:41 AM
ChrisM
Sep 3, 2008 09:26 AM
60Olds98
Ninety-Eight
Aug 22, 2008 05:30 PM
todd66442
Tech Editor's Desk
Aug 12, 2008 07:43 PM
