65 Holiday Coupe VS Post
Old Apr 26, 2018 | 08:32 AM
1965-442's Avatar
My dad and I have a 65 442 Holiday Coupe. The rear quarters and rear wheel wells are rusted beyond our repair skills.
We have been looking for another body, like an F85 or cutlass to rebuild this car. Finding a lot more post cars than coupes..
What would have to be done to a post body to run our holiday coupe doors etc.? Just removing the post?
Old Apr 26, 2018 | 09:39 AM
stan 65 cutlass's Avatar
the doors are about the only thing not interchangeable on your car, honestly these days the post cars are more desireable than our hardtops
Old Apr 26, 2018 | 09:57 AM
1965-442's Avatar
Well.. the old man is stuck on the holiday coupe.
So if we found a post body, we could cut the post out and use our doors & glass etc?
Anyone know of a build thread on this? I tried the search..
Old Apr 26, 2018 | 11:35 AM
no, i think your hardtop doors will only interchange with a convertible
http://w29.boards.net/
heres another site, try your question there, alot more knowledgeable guys than myself
Old Apr 26, 2018 | 02:46 PM
The basic outer sheet metal panels are the same, however you can't just "cut the post out", you need to carefully transfer the hardtop window seal supports and other metal from the original to the donor body. The rear quarter window mechanisms and guides are completely different on the two bodies, as is the glass and the fact that the HT quarter window seals to the door glass (unlike the post car). This can certainly be done. It's a LOT of careful cutting and welding. It might be a lot easier to use the post quarters on the HT shell, for example.
Old Apr 27, 2018 | 10:51 AM
1965-442's Avatar
Posted the same question on the w29 boards, thanks stan!
Joe, yeah I figured there would be some metal to transfer there.. just wondered how tough it would be, if it was even possible. We bought floor pans and trunk pans for this car, then we started sanding around the rear wheel arches.. lots of bondo was found and the car is pretty far gone back there. Thought about cutting up some front fenders to repair but it's pretty bad!
There are a lot of 65's out there, just need to find the right one. Find a good body close to us and it's a post.. go figure. Too bad they don't make rear quarters. ugh
Old Apr 27, 2018 | 04:12 PM
oldstata's Avatar
Justin
Easier to swap quarters than the roof!! Just my opinion
take a look at my build
“kids helping with project” I did about 80% while being guided by a friend in the auto collision field.
We patched the rear quarters with door skins and fenders sections
it turned out okay for what it was looking back I have found a lot of guys using the skins from the 65 impala with modification also the 65 chevelle with modification
Old Apr 28, 2018 | 11:46 AM
This falls into the "it can be done, but why would you" category. Sure, you can do it, but it will probably never be perfectly right, and it would be a lot of time and effort for not much gain. I would look for a good hardtop donor in the west, and do a rebody.
Gearhead442
Sep 6, 2023 05:30 PM
coldfire
Aug 13, 2019 08:08 PM
btw
Cars Wanted
Jul 24, 2017 05:44 PM
1970w30
May 24, 2011 07:31 PM
oils66
Nov 25, 2009 08:25 AM
