Odometer swapping
Old Jun 25, 2016 | 12:13 PM
Rocketbrian's Avatar
Odometer swapping
I replaced the speedometer in my 71 442 as the needle wasn't acting correctly. Is swapping the odometer section from the original speedo into the replacement unit difficult? They are approximately 40,000 miles apart so I would like the correct mileage showing. Thanks
Old Jun 25, 2016 | 12:54 PM
It isn't difficult, but it does require care as there are fiddley little parts to align. It's also very easy to simply set the odo in the new speedo to the mileage you want.
Old Jun 25, 2016 | 02:42 PM
Is there a step by step procedure to reset the odometer on this forum? Resetting sounds more favorable than switching the odometer units themselves. Any help on this would be most appreciated. Thanks Joe for the info.
Old Jun 25, 2016 | 03:24 PM
oldspackrat's Avatar
Brian,
I have restored many of these speedos, & also fuel gauges, & can give you step by step instructions but it is easier over the phone than internet. Feel free to give me a call when you can & I'll guide you through it?
Scott
c. 317-727-7041
Old Jun 25, 2016 | 09:01 PM
Yes, it's been posted here before but here ya go. Although this is blue oval, the pieces and principles are the same for GM. I took one apart at the boneyard and it wasn't hard. Keep yourself organized and put parts where you know where they are.
Old Jun 26, 2016 | 04:47 AM
rob1960's Avatar
I'd get one of these alignment strips before you work on your speedo. It pushes over the lock tabs on the odometer numbers & keeps all the numbers lined up. It's made of thin plastic & after 40 plus years it'll be very brittle & will probably break when you try to take it off. The parts place has it for $5 pt#IN3643Z. All the numbers on the roll won't stay lined up without it.
Old Jun 26, 2016 | 06:22 AM
Thanks everyone for the help, very much appreciated. I have a few spares so I have back up if a part breaks.
Old Jun 28, 2016 | 12:48 PM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
alternate method: jack up the car rear end, start it, place in reverse, let run for a while
its better if you do it in a house on stilts. with all glass walls.
idaholc
Mar 19, 2011 09:05 AM
jaunty75
Sep 18, 2009 07:26 AM
56oldsnub
Ninety-Eight
Dec 21, 2008 05:40 PM
shaks 442 clone
Feb 14, 2008 03:48 AM
tpkj
Mar 11, 2005 04:46 PM
