Reconditioning thermostat housing
Old Apr 2, 2016 | 05:30 PM
yellowrocket's Avatar
Hi, was looking to get some input about the bypass tube on my thermostat housing. I was looking for information if anyone has removed the tube , how they did it and how it is put together. I have a source thru my job where I can have the tube replated if I can get it separated from the cast piece.
Old Apr 2, 2016 | 06:03 PM
don71's Avatar
same but different
I admire your taste to detail. I've not read discussions on removing the tube.
My opinion, its not worth it.
Just blast your current piece and paint. If thats not good enough, get another one.
Old Apr 2, 2016 | 06:26 PM
76olds's Avatar
Hookers under Hood
I have to agree with Don, not worth the effort.
I believe they were silver soldered in place.
You would destroy the pipe and possibly the housing before getting it out.
Old Apr 2, 2016 | 08:22 PM
76CutlassSalon's Avatar
yellow,
Has the tube come out? Is it rusted out? If so, then yes the housing should be replaced as the others have stated.
With ours, the tube wasn't loose or damaged so I just resurfaced the corrosion on the gasket mating surface with 180 grit on a belt sander, repainted and reinstalled it with a new T-stat and gasket and called it a day.
Jeff
Old Apr 5, 2016 | 05:18 PM
FStanley's Avatar
I like the generic black thermostat gasket from Oreilly, seems a bit thicker then a felpro. I like ultra blue RTV, both sides, then let it cure overnight.
Re-Check torque after warm up and cool down.
never had a leak yet on about 20 Olds engines..
Boilerz25
May 6, 2014 06:16 AM
csouth
Jan 4, 2010 07:04 AM
5hundo
Body work
Aug 13, 2009 12:57 PM
5hundo
Jun 18, 2009 11:13 AM
metro411
Dec 27, 2007 11:10 AM
