Rod reconditioning
Old Dec 29, 2009 | 11:48 AM
csouth's Avatar
Rod reconditioning
What should I expect to pay for this service? Also, will the pistons need to be pulled for the big end to be done?
Old Dec 29, 2009 | 01:09 PM
To recondition the rods the pistons need to be removed.
Old Dec 29, 2009 | 01:13 PM
csouth's Avatar
Thanks. Would you happen to have a ballpark figure of what that should set me back
Old Dec 29, 2009 | 03:00 PM
442Harv's Avatar
I looked at my last eigine I had worked on, and it was all added to a lump sum, of a lot of different things done to the block, which was $400, which was quite a bit of work, so I think the rod resizing was a small amount, like less than $100, more like $75?
Old Dec 29, 2009 | 08:20 PM
64Rocket's Avatar
A $100 seams to be the going rate. That is what I charge.
Gene
Old Dec 30, 2009 | 05:40 AM
The question is... Why would you have the rods reconditioned and not bore the block, line hone the mains, true the deck, and recondition the crank?
Old Dec 30, 2009 | 07:38 AM
cutlassefi's Avatar
Excellent question. Chris, carefully consider all your options.
Apparently things are more expensive here in Fl. The going rate here is $15.00 per rod to recondition and $5.00 per rod to press the piston on and off. By the time you buy new bolts you're over $200.00.
Now do you see why I'm such an advocate for using aftermarket parts?
Old Dec 30, 2009 | 09:24 AM
AJCDFIN's Avatar
That seems like a fair price for R&R P's,cleaning & recon. Actually $5.00 to R&R P's is on the low side.
No (quality) engine rebuild would be complete with out this procedure.
Old Dec 30, 2009 | 11:16 AM
csouth's Avatar
All the block and crank work has been done. I bought the pistons pressed on rods from someone that wanted higher compression pistons and h beam rods. They pistons are in excellent condition, appears the motor may not have even been broken in. Since the bolts look original and the condition of the rod is something I cannot eyeball, I want to make sure of it before installation.
Old Dec 30, 2009 | 01:37 PM
Oh...
Old Dec 31, 2009 | 01:37 PM
AJCDFIN's Avatar
Hey csouth; You can have a machine shop check the rods with the p's on. As far as the bolts go, if you are going to replace them please do not attempt this with out reconditioning them(rods). Too many times people do this with out reallizing the consequences.
Old Jan 1, 2010 | 05:43 PM
csouth's Avatar
Thanks. I will have them checked before I have the work done. I would hate to pay for something that is not necessary.
Old Jan 2, 2010 | 07:37 PM
captjim's Avatar
Clarification time. I think you guys are confusing "resizing" with "reconditioning". There is absolutely no reason that you can not replace the rod bolts and resize the big end of the rods to fit your crank journal with the pistons on. Done it many times, no biggie. Cost should be $100 +/- Now, to "recondition", shot peen, resize, etc, yes, the pistons need to come off. Plus, there is is the issue of balancing, in which case the rods and pistons need to be separated.
Old Jan 4, 2010 | 06:48 AM
You are right Cap'n. I guess it just seems like wasted time to me to have the crank end of a connecting rod "resized" without have the entire rod "reconditioned."
Old Jan 4, 2010 | 07:04 AM
Texas Jim's Avatar
Texas Jim
64Rocket, Do you personally know of a good Olds-knowledgable machine shop in the Central Texas area? I have a '71 455 that I'll be installing in my '62 Ford pick-up. I'd really like to send my block, heads and rotating assy. to a good shop, one of the few greats that I see on the site, like yourself, but checking on shipping prices has changed my mind. Even prior to leaving and going over-seas f/ 6 years, returning recently, I wasn't aware of any Olds "masters" machine shops around here. Any suggestions would be seriously appreciated. Thanks in advance.
Boilerz25
May 6, 2014 06:16 AM
widowmaker1201
Dec 2, 2012 01:52 PM
5hundo
Body work
Aug 13, 2009 12:57 PM
5hundo
Jun 18, 2009 11:13 AM
tazmangk
Sep 24, 2007 07:17 PM
