Rebuilding a 394 Fuel Pump
Old Dec 21, 2015 | 12:46 PM
Larry/car's Avatar
As promised I will describe the rebuild of my 1961 Dynamic 88 fuel pump. Fuel pump rebuilds are not fun, I will never do another. This thread will require multi posts to finish. Here we go; The fuel pump started to leak oil but otherwise remained operational. I searched the maintenance manual and decided should be fun, yea right! IMG_0468_zps25886a63.jpg Here is the fuel pump prior to removal. Disconnecting the vacuum lines, the fuel line from the tank, the pressure line to the fuel bowl and removal of two bolts had the pump on the bench in no time. I also removed the generator drive belt to gain access. IMG_0523_zpso6taxttv.jpg Fuel pump has been cleaned prior to teardown. The manual says to start with the fuel pump sideIMG_0525_zpswdsylcqb.jpg. Removing the four screws allowed access. Still fun at this point. IMG_0527_zpsy0t2gwtw.jpg
Here you see the fuel in and out valves. Next I removed the screws separating the diaphragm housing from the valve assembly, a slight tap broke the seal exposing the diaphragm. IMG_0528_zpskw8kzbzt.jpg
Up to this point everything proceeded as expected. Now the manual says to tip the diaphragm and unhook the rod from the pump actuator arm. Years of crud prevented the rod from sliding off the end of the actuator arm. I pushed on the spring and tilted the diaphragm, wouldn't release! I attempted to get the darn thing to release all week. After much thought I decided to drill the diaphragm end which would allow more ability to position the rod and not have to depress the spring. The process worked and after repeated attempts the rod separated, YES. IMG_0529_zps2uza4zcy.jpg
Old Dec 22, 2015 | 08:19 AM
Larry/car's Avatar
Here we have the drilled diaphragm and the separated rod arm. Note the crud that was under the diaphragm. Check the rod seal in the housing, it age hardened allowing the oil to enter the chamber and vent overboard, reason for repair. Now how to remove the seal from the housing?IMG_0531_zpsugjonq0h.jpg
Old Dec 22, 2015 | 08:25 AM
Larry/car's Avatar
I devised a fixture using a bolt head to fit under the retainer and pull the seal out of the IMG_0532_zpsclbuuwha.jpghousing, by alternating from side the seal retainer came out easily (to my amazement). That concludes the fuel pump disassembly. On to the vacuum side. Turning the pump housing over I proceeded to remove the screws holding the vacuum housing together. There is a strong spring on top of the diaphragm that really pushes as you separate the housing halfs. Exercise care not to damage anything including yourself. Notice spring seat on top of exposed diaphragm.IMG_0539_zps8od0z0uk.jpg h IMG_0538_zpsn9k79ldx.jpg
Old Dec 22, 2015 | 08:54 AM
Larry/car's Avatar
This is what was hiding under the diaphragm! IMG_0541_zpsqwtpyn39.jpg The rod seal has been removed with the same process as on the pump side. Notice the vacuum valve, removed prior to cleaning. (there is a gasket under all the valves). IMG_0551_zpss1ayvjsd.jpg The vacuum diaphragm separated from the actuator rod with just a quarter turn of the diaphragm. Now the really fun part of the process begins after cleaning. The diaphragm assembly is not part of the kit (just the rubber seal) and the rod has to be pressed out enabling you to replace the seal. I had access to a press and help from a friend to accomplish the procedure, took us three hours to accomplish. IMG_0552_zpspqmlwfdn.jpg At this point I was sick of it and didn't take pictures of the installation of the valves. The process is strait forward; remove the valves by tapping them out, cleaning the recess, install gasket, press in place (carefully pressed in place with a C-clamp) staked housing to hold valve with a sharp center punch.
Old Dec 22, 2015 | 10:20 AM
Larry/car's Avatar
After all the valves and seals are in place it is now time to begin assembly. Manual says to start with the fuel side. The fuel diaphragm has to be attached to the pump actuator rod. I dreaded this process from the time the old diaphragm rod finally detached itself. Tilting the diaphragm assembly and slowly/carefully inserting the rod into the seal I heard a click, "yes" it just slid into place. The diaphragm has to be positioned flush with the pump housing in order to attach the valve assembly to the pump with the diaphragm seal sandwiched in between. The screws started easily and I slowly tightened, the manual says to flex the diaphragm prior to final tightening. With that procedure accomplished I torqued down the screws. Cycling the pump actuator I felt suction on the fuel in side of the pump, a good sign. IMG_0529_zps2uza4zcy.jpg Picture of original diaphragm (didn't take a picture of replacement). You slowly cycle pump actuator to bring diaphragm to pump housing and secure in place to assemble unit.
Old Dec 22, 2015 | 10:38 AM
Larry/car's Avatar
On to the vacuum side: The vacuum diaphragm is attached to the actuator with just a quarter turn of the diaphragm assembly. The diaphragm rubber seal has to be positioned appropriately to align the holes with the housings and have the rod in the proper position (90 degrees) attached to the pump actuator. A strong spring is positioned on top of the diaphragm as the pump is assembled. This presented a problem as the screws are not long enough. I adjusted two C-clamps to provide the proper distance needed to start screws without applying undue pressure to the assembly. I slowly tightened screws to secure assembly to the pump. Again I flexed the new diaphragm to relieve undue stress. IMG_0558_zps9facrszf.jpg
Old Dec 22, 2015 | 10:52 AM
Larry/car's Avatar
Engine ready for install: IMG_0560_zpsax6nhm8p.jpgIMG_0557_zpspqw2kfyu.jpgPump is now lubed before installation, have no idea how long it would take the engine to provide lubrication to actuator and the diaphragm rod seals so I squirted engine oil into the pump. Should prevent excessive seal wear on initial operation. I also added gasoline into the pump to provide valve lubrication on initial start up. The pump installation is fairly strait forward and no problems arose.
Old Dec 22, 2015 | 11:10 AM
Larry/car's Avatar
The engine cranked for what seemed forever (hoses were dry) the cylinders started to hit and the engine settled into a smooth idle. IMG_0564_zps0sjgjtn2.jpg After determining there were no leaks I took the car for a short drive. The car performed normally. IMG_0565_zpsssefgdz3.jpg Another successful repair!!!!!
Old Dec 22, 2015 | 11:29 AM
Larry/car's Avatar
I hope this presentation was educational and gives you an idea what is involved in overhauling a fuel pump (same procedures are required on similar mechanical fuel pumps). I decided to rebuild my pump because the car only has 44,000 miles. Replacement pump mileage is unknown. Another reason; these cars are old and replacement parts could sit on the shelf for years, seals could be as bad or worse.
Old Dec 22, 2015 | 02:36 PM
Luch's Avatar
Thanks for the terrific write up! Looks like the 394 has a real 'special' fuel pump. Never rebuilt one but this would sure help. appreciate the time you took to do this, its a help to those of us that need it!
Chris
Old Dec 22, 2015 | 04:59 PM
Larry/car's Avatar
My pleasure. As our cars age we need to share this kind of information. I got the pre-run lubrication idea from reading problems others have experienced with premature seal failure, with only a few thousand miles on the clock. Purchasing new old stock pumps that have been sitting on the shelf for fifty years or more. The rubber seals could be in worse shape than in the pump you are replacing.
Old Dec 22, 2015 | 05:35 PM
Tedd Thompson's Avatar
When I rebuilt mine I also found the screws were too short so I used three I believe 8/32 X 2 inch screws rather than the C clamps, same difference at the end but I found it easier to align the pump top with the screws. After I had pulled the diaphragm top down till the short screws started easily and then replaced the long screws. Lucky for me my diaphragm rod did not stick as yours did. I probably would have junked it at that point. .... Good post and pictures... Tedd
Old Dec 23, 2015 | 06:15 AM
Larry/car's Avatar
That fuel diaphragm rod was quite a problem. The vacuum diaphragm seal replacement was the hardest part of the challenge. I am guessing a new replacement vacuum diaphragm assembly is no longer available so we now have to rebuild the old one. Without a press I am not sure that a successful rebuild would of been possible. Squeezing the seal between the metal plates proved quite a procedure. I should have taken pictures, I was taken back by having to perform the diaphragm rebuild.
Old Dec 23, 2015 | 02:25 PM
therobski's Avatar
Great job Larry, same pump with vacuum on my 62 Dynamic 88.
Old Dec 23, 2015 | 03:07 PM
Larry/car's Avatar
This pump is used on 1959 through 1962. There are various versions, check the pump base for model number.
Old Jan 5, 2016 | 03:14 AM
stocki26's Avatar
Smile
thank you for showing that - helps a lot
Larry/car
Dec 20, 2015 05:41 AM
1964super88
Mar 24, 2014 09:35 AM
442oldslawyer
May 14, 2010 10:04 PM
sshriber
Mar 22, 2010 06:16 PM
lowdynamo
Jan 10, 2009 03:36 AM
