1957 Oldsmobile Fiesta Hood..
Old Jul 9, 2016 | 04:56 AM
Oldswag57's Avatar
Hi guys how are you , just wondering if someone could help me out with adjusting the hood . What is the best way of doing this , the hood sticks up at the windshield end both corners , how can I adjust them down ..Thanks
Old Jul 9, 2016 | 07:46 AM
redoldsman's Avatar
Proud Viet Nam Veteran
If you have a shop manual it should tell you how to adjust the hinges. If you don't have one, I would encourage you to get one. It is the best thing an old car owner can have. You can find them all over ebay at varying prices. The hood hinges on my 54 adjust from bolts on the backside of the firewall inside the car. I don't know if the 57 is the same but get a flashlight and take a look.
Old Jul 9, 2016 | 08:34 AM
Rocketowner's Avatar
Will they go down if you push on them when it is supposedly shut? If not, have someone push upward on the front end of the raised hood ,while you watch the movement at the hinge where the"rivets" go through the holes .Watching closely while the are pushing up then down on the hood you may detect some movement(slack)at those connections. If so, your hinges are worn oblong causing slack and your hood will not pull down at the back when shut. There are places that rebuild the hinges listed online ,or you may be able to weld the holes up some and re-drill them and replace the rivets ,which are available online . Best of luck, Larry
Oldswag57
Feb 14, 2015 04:40 PM
ClassicCars
Cars Wanted
Apr 11, 2011 07:33 AM
christl
Jun 7, 2010 01:31 PM
christl
May 2, 2010 09:46 PM
christl
Cars Wanted
Sep 18, 2009 10:22 AM
