Will a 68 GTO steering column fit my 67 Cutlass
Old Mar 19, 2016 | 09:18 PM
squirell's Avatar
Govt slave
Hi Guys,
I finally found some buckets and console for my 67 Cutlass (automatic column shift).
A buddy has a good automatic floor shift steering column out of his 68 GTO (no key on column).
I think it should be a straight swap...anyone know anything different ?
Old Mar 20, 2016 | 10:38 AM
marxjunk's Avatar
way diff..but can work
67 the intermediate shaft is made into the column, actually it doesnt have one..its a 1 piece column and the first year for collapsible column..67 is a one year column..the intermediate shaft is the shaft that bolts to the steering box
68 the steering column and intermediate shaft separate..2 pieces...and the length is a little diff...if you free up the intermediate shaft so it telescopes and slides it can go in there..but theres still other things..
67 non tilt columns are not hard to get..ive had and sold a 100+ of them and they bring 75 to 150 for good uses ones
67 column in a 67 is a bolt in..and the floor shift columns from skylark, lemans, and cutlass interchange..
67 chevelle is unique and you have to do things to it to make it work..it will..its going to need a few mods and doesnt meet the dash right..
Old Mar 21, 2016 | 12:52 PM
squirell's Avatar
Govt slave
so if I understand you correctly....if the intermediate shaft slides I can make it the right length.
Is the wiring the same ?
Will it bolt to the steering box the same ?
You said "but theres still other things"...what are they ?
Thanks,
Matt
Old Mar 21, 2016 | 08:29 PM
marxjunk's Avatar
the mount to the bottom of the dash is completely different..completely..you have to figure that out
yes you can free up the shaft..it is plastic injected like a stock original u-joint..you heat it up, the plastic runs out and while its hot you make it slide and then its adjustable
bolts to the steering box the same..leave the box half of the rag joint on the box use the 68 half of the rag joint on the column and bolt it together
wire harness is diff...they are the same amount and color of wires, just the connector is diff and they are in a diff order..easy to fix.
you should really look for a 67 column..your life depends on it..and i dont know what you skill level is..
just buy a bolt in and go..the diff in pricing cant be much..and theres prob more 67s columns out there than you think..if you lived in a spot where nothing was ever avail..then think about mods..
66 down is completely diff and wont work with out a bunch of work
Old Mar 21, 2016 | 08:55 PM
squirell's Avatar
Govt slave
Thanks for the input...I think I'm gonna listen to your advise and try and find a 67 BOP Column.
Old Mar 21, 2016 | 09:11 PM
67 Cutlass Freak's Avatar
I have a '67 column out of my race car. It is blue, 2 speed, column shift. I will sell it for $100 plus shipping.
Let me know, dave - the Freak
Old Mar 22, 2016 | 04:56 PM
squirell's Avatar
Govt slave
Thanx for the offer ,but I have a column shift and am looking to install a console shift
Old Mar 27, 2016 | 11:03 AM
squirell's Avatar
Govt slave
this would be the easiest solution right ?
http://www.ebay.com/itm/1967-Pontiac...tWaeNN&vxp=mtr
Old Mar 27, 2016 | 03:49 PM
marxjunk's Avatar
yes you could convert yours with that collar...while its apart grease the bearings etc...it takes a little time but its really easy to do it.
but honestly...thats a 50 dollar part...but if you are tired of looking its not terrible
Old Mar 27, 2016 | 07:01 PM
squirell's Avatar
Govt slave
I agree it's a $50 part at most, but I have never seen another"just the collar" for sale...I'm sure as soon as I decide to buy it, I'll find one for $10....story of my life...LOL
camshaw
Jun 29, 2015 03:09 AM
317Cutty
Jun 18, 2014 10:53 AM
Chumpy2112
Jul 13, 2013 09:59 AM
Vistabrat72
Jan 8, 2012 05:11 PM
Danielle's 71
Apr 14, 2009 07:32 AM
