1974 Cutlass Tilt Steering Column, will it fit a '72?
Old Jan 7, 2012 | 06:44 PM
Vistabrat72's Avatar
Another 'can't leave well enough alone' project, aside from having to modify the bracket that the shift rod has to go into, can a tilt steering column from a '74 Cutlass be fitted into a '72 Cutlass/Vista Cruiser. Thanking all in advance who have been down this road. Howie
Old Jan 8, 2012 | 01:27 PM
I do not have first hand info on this, but I have been told that the 73-77 columns will interchange with the 69-72 columns, with one exception. The arm that connects to the shift/backdrive linkage at the base of the column is shaped differently. You might need to modify the rod that runs from this arm to the trans to get it to work correctly.
Old Jan 8, 2012 | 05:11 PM
Joe, thanks for the information, I have seen you are a total wealth of knowledge and information to many on the forum. From rough measurements, etc, and I even have the intermediate collapsible shaft from the newer unit as well, it did look doable. This helps much, I did observe the difference in the shape/radius overall of the shift arm, it does not look to difficult to overcome. So another one in the works for the car, it can now take a number!
starfire
Dec 9, 2021 08:21 PM
317Cutty
Jun 18, 2014 10:53 AM
ros6872
Mar 28, 2014 09:48 AM
BeenThere
Apr 13, 2013 05:52 AM
ELECMAN
Jan 22, 2012 01:49 PM
