Changing hood hinge and spring
Old Mar 29, 2016 | 05:52 PM
Rocketbrian's Avatar
I need to replace the hood hinge on my SX, as it drops about an inch at the back just before it is in the fully closed position. I presume the pivot is worn out. In order to do this is it safest to remove the hood, or is there a method to do it with the hood still on that is fairly uneventful? Should the spring be removed while on the car or off and what is the best method? Anybody able to offer suggestions? Thanks.
Old Mar 29, 2016 | 06:50 PM
lemoldsnut's Avatar
I never do this alone. I use more than one person everytime. Even three is nice. I place thick rags like towels at the firewall just under the back corners of the hood. Then remove the upper or forward hood bolts first while two support the hood then the back bolts. I usually put the hood on the roof but I have a few shipping blankets on it and the windshield to protect them. Then removed the bolts that hold the hinges to the fenders and replace them.
I can do a good set of hood hinges with springs.
Larry
Old Mar 30, 2016 | 05:44 AM
I was thinking removal of the hood is best, I don't want to risk any damage. I do have a replacement hinge, thanks.
Old Mar 30, 2016 | 06:00 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Always replace the springs and hinges as a pair. You said "hinge" as in singular above.
Old Mar 30, 2016 | 06:58 AM
My442's Avatar
SMS in New Hampshire rebuilds and re-phosphates hood hinges.
They do a great job.
Old Mar 30, 2016 | 09:00 AM
Thanks for the info.
RetroRanger
Nov 11, 2024 09:45 AM
johnnyjaws
Feb 23, 2015 04:30 PM
ffaybar
Feb 22, 2013 09:54 PM
Texas442
Mar 5, 2011 10:20 AM
squirell
Dec 6, 2009 09:01 AM
