1970 Engine assembly Manual
Old Jan 4, 2025 | 05:21 PM
Prosconst's Avatar
is it worth purchasing the engine assembly manual or does it contain the same information that is in the regular assembly manual?
Thanks,
Jim
Old Jan 4, 2025 | 08:07 PM
Hairy Olds's Avatar
Shoveling Snow
The engine assembly section usually does not come In the PIM except for the one I sell.
I also sell the 1970 engine assembly section on it's own.
Old Jan 5, 2025 | 12:42 AM
Thanks,
Jim
The engine assembly manual has info that is not covered in the regular PIM. There is a lot of info on exactly what components were used for each engine configuration. The tables at the back are packed full of useful info but can be difficult to understand for those not used to reading engineering drawings. Also note that this document calls out PART NUMBERS, not casting numbers. Rarely are those the same. Also, some things like water pump are not shown, as the engine assembly manual only calls out the P/N for the "shop assembly" of a water pump on the front cover. Cylinder heads are listed by P/N, so small valve E heads have a different P/N than do big valve E heads, and neither relates to the casting number directly.
Old Jan 5, 2025 | 08:54 AM
Prosconst's Avatar
Where do you sell this at?
Old Jan 5, 2025 | 09:01 AM
Hairy Olds's Avatar
Shoveling Snow
Contact me thru a PM.
Old Jan 5, 2025 | 10:42 AM
Buy one from Hairy Olds (Paul). Good quality, I have a couple of them.
Old Jan 13, 2025 | 05:32 PM
Prosconst's Avatar
Received Paul, thank you
rfpowerdude
May 25, 2023 09:27 AM
chrisneu68olds
Jul 15, 2016 02:02 PM
Cincinnati Rick
Jan 15, 2015 02:31 PM
Hairy Olds
Oct 31, 2009 12:47 PM
