Fuel pump to carb fuel line routing 69 442
Old Jun 24, 2025 | 07:26 PM
Kevin's442's Avatar
Hello everyone,
I'm installing the new pump to carb fuel line I purchased from Fusick's and things aren't lining up quite right. Everything is original equipment, the pump, the carb and the intake manifold. The Chassis Service Manual illustration calls for the brass fitting on the pump outlet to be pointing straight up on 400 and 455 engines. If I orient it that way, the fuel line isn't lining up with the fitting. I don't have a problem changing the angle of one of the bends in the fuel line to make it fit, but I want it to follow the original factory design as closely as possible. Does anyone with a stock 69 442 or Hurst Olds have a picture of the carb fuel line position? Thanks in advance.
Old Jun 26, 2025 | 06:46 AM
442operator's Avatar
Photo of 69 442 Carb/fuel line
This is how mine looks. I think its correct.
Old Jun 26, 2025 | 07:43 AM
Kevin's442's Avatar
Thanks, 442operator.
Looks like mine is following the same path. The problem with mine was it went above the lines coming out of the vacuum tree on the intake manifold. I was able to change the alignment of the 90 degree bend outboard of the vacuum tree so it could sit lower without hitting the intake manifold. Once I did that, it runs BELOW the lines coming out of the vacuum tree and everything else pretty much fell into place at that point.
Thanks again for your help.
origowner77
Apr 16, 2025 07:44 AM
mdd71
Aug 15, 2024 03:54 PM
eggydrummer
Mar 31, 2024 08:55 AM
mefirst72
Feb 10, 2013 06:37 PM
boondocker
Aug 13, 2011 10:53 AM
