Head gasket question
Old Oct 24, 2025 | 03:37 PM
jrhotes's Avatar
Why does the head gasket appear to cover 16 of the 18 coolant passages from the block to the head….69 350.
Car has been progressively getting worse and overheating over the past five years.
Head gasket appears to be same for 1964-1991 olds v8.
Help
Old Oct 24, 2025 | 04:04 PM
Most of those passages are there for the casting process and are not intended for coolant flow. The head gasket has the correct openings for proper coolant flow.
Old Oct 25, 2025 | 06:19 AM
Why do people always think that the head gasket is made wrong? Do you really think the engineers who designed the engine were that stupid? Yes, someone asks this same question every time they pull a head for the first time.
As noted above, the block is made with a sand casting process. Getting the sand cores out of the block after casting is always a problem. That's why there are freeze plug holes on the sides of the block. The extra holes in the deck are also passages to get the sand out of the casting. Look at the cooling system diagram in the Chassis Service Manual. The flow of coolant in the engine starts at the water pump, flows backwards through the block around the cylinders, goes up into the head, then flows forward in the head to the t-stat crossover at the front of the intake manifold. There are a couple of carefully sized holes in the head gasket to allow SOME coolant to flow from the block to the head, but most of it goes all the way back first. If you opened up all those holes in the gasket, coolant would take the path of least resistance, which would cause it to immediately flow up into the head and out the t-stat. The result would be that the back cylinders would run way too hot.
Old Oct 25, 2025 | 07:51 AM
jensenracing77's Avatar
Why do people always think that the head gasket is made wrong? .
In todays quality control world I question everything.... Sure, some things are more obvious to some of us but I have been asking somewhat dumb questions out of fear of the lack of quality these days.
Old Oct 25, 2025 | 09:22 AM
If one is asking about the OEM gasket that came out, QC isn't an issue. And while I've had even brand name stuff that was made wrong (like the batch of FelPro gaskets that had the four locating bosses stamped incorrectly some years ago), one should ALWAYS compare the new parts with the old ones.
Old Oct 27, 2025 | 07:07 PM
CANADIANOLDS's Avatar
Help
ignore Joe Pee…he’s an angry old man who needs to prove to everyone he’s smarter than everyone, even those who never opened up an Olds before.
Old Oct 27, 2025 | 07:16 PM
I never got that impression. You, on the other hand…. Well, let me just say that your attitude could use some improvement.
Old Oct 27, 2025 | 08:37 PM
you should mind your own business ..don’t answer for someone else.
Old Oct 28, 2025 | 08:17 AM
OLDSter Ralph's Avatar
You should take your own advise.
Old Oct 28, 2025 | 09:16 AM
if that ever happens…I’ll think about it.
Old Oct 28, 2025 | 01:43 PM
Old Oct 28, 2025 | 04:42 PM
In fact, some of them are ...
jb77
May 12, 2021 12:56 PM
70cutty
Aug 28, 2013 04:35 AM
my71olds
Aug 14, 2013 05:49 PM
richeyb
Oct 14, 2010 04:14 PM
1969cutlazz
May 16, 2010 08:07 PM
