.080 head gasket
Old May 12, 2021 | 01:53 AM
jb77's Avatar
.080 head gasket
Hi, i need an alternative for the cometic or sce 4.200, .080 head gasket.
I need this thicker type of gasket. The Sce or Cometic are currently 12-14 weeks away on back-order. //JB
Old May 12, 2021 | 12:46 PM
BillK's Avatar
Not sure if this will help or what your actual application is but these guys make steel shims to use under head gaskets. I have used them several times in the past to save aluminum heads that need to be milled too much.
https://innomach.com/cylinder-head-shims
Old May 12, 2021 | 12:56 PM
jb77's Avatar
Thanks! Will check them out.
70cutty
Aug 28, 2013 04:35 AM
my71olds
Aug 14, 2013 05:49 PM
coppercutlass
Oct 25, 2011 04:38 PM
Joel
Mar 7, 2011 10:45 AM
richeyb
Oct 14, 2010 04:14 PM
