What is the thinnest composition head gasket?
Old Mar 6, 2011 | 10:18 AM
Joel's Avatar
What is the thinnest head gasket available without going to solid copper? Can I get .020"?
Thanks, Joel
Old Mar 6, 2011 | 11:02 AM
TripDeuces's Avatar
I think the stock GM are .017. Mr. Gasket are .015? You said composition gasket, are you talking layered kind like MLS (multi layer steel)? Those are thicker with the thinnest being .027
Old Mar 6, 2011 | 11:27 AM
Joel's Avatar
Thanks for the info! I have a composition in my gasket set that is about .044, and I thought that was too thick. So I looked on summits web site and all they had was thick stuff or copper. If I can find a stock steel type gasket, that should be fine. Or a .015 mr. gasket should be even better. Where do they sell those? Anyone have a part #? thanks
Old Mar 6, 2011 | 11:52 AM
TripDeuces's Avatar
Rock Auto sells them in FelPro and Victor Reinz, about $15-17 each. GM doesn't make them anymore but I'm sure these are close in thickness.
Old Mar 6, 2011 | 07:42 PM
380 Racer's Avatar
I don't think you will find a composition gasket thinner than .028. I think the GM steel shim gaskets were .018. I believe the Cometic get down to .020-.024. This is what I have heard and could be all wrong.
Old Mar 7, 2011 | 06:27 AM
Run to Rund's Avatar
Corteco 55661 is .028" thick.
Old Mar 7, 2011 | 10:45 AM
Joel's Avatar
Thanks for all the help. I suppose I could use a stock type, embossed steel gasket. What I was thinking when I said composition, is that I just didn't want a plain flat copper gasket.
Bobac455
Dec 4, 2013 09:23 AM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
