400 bore
Old Mar 4, 2010 | 04:02 AM
442oldslawyer's Avatar
400 bore
I have bored serveral 400 engines .30 over but now need to go .40. Is this OK?
Old Mar 4, 2010 | 04:03 AM
Also 2 cys need slieves. Thought on that?
Old Mar 4, 2010 | 04:29 AM
70 cutlass s's Avatar
I would look into finding another block before I send that much on that one. Start a tread in the parts wanted section and see what happens.
Old Mar 4, 2010 | 06:17 AM
2blu442's Avatar
My favorite machine shop will put in a sleeve for $80. For normal driving I've heard they're OK. John
Old Mar 4, 2010 | 06:26 AM
Oldsmaniac's Avatar
If you are talking about E block 400's they have very thick cylinder walls since they can be bored out to 425ci so an .040 is nothing to worry about.
Old Mar 4, 2010 | 06:41 AM
Years ago, Chris Witt claimed that he saw a cutway G-block 400 with very, very thick walls. In any case, I have yet to see a 1960s cast iron block that couldn't be safely bored 0.060" over.
Old Mar 4, 2010 | 07:35 AM
The engine has already been built with 2 sleeves and bored .40 over. My machine shop certifies that it has what is listed by the engine builder. Has 800 miles and was running at the time of removal. Ran good with no knocks, ticks or smoke. I can buy it for $1500. What do you think.
Old Mar 4, 2010 | 07:36 AM
Warhead's Avatar
Ditto Joe, plus if you need to sleeve it, I have 2 blocks that I have sleeved, and have pounded the living tar out of them with NO issues. G or E block you have NOTHING to worry about.
If it is a 442 engine with all the trimmings, manifolds, and air cleaner etc, then yes, it is worth it.
A long block.....not so much.
Jim
Old Mar 4, 2010 | 08:27 AM
TK-65's Avatar
Many people have went with the 350 Olds piston in the early 400. To do this you need to go .057 out, so .040 is nothing to worry about.
Old Mar 4, 2010 | 11:13 AM
Yes, but this only works in the short-stroke 400 motors. I don't think we ever were told which the O.P. has.
Old Mar 4, 2010 | 11:44 AM
Thanks for the infomation. Now I can make a choice of engines offered on something besides difference in price.
Old Mar 7, 2011 | 01:32 PM
Red71's Avatar
yep I just noticed that also. he may be talking about the 68 / 69 400.
if this is the case then most off the info posted here is about the 400 "B' and "E".
either way if the sleeve job done properly it would probably
hold up better on that cylinder because the material is usually better
then the cast block.
hilbily
Nov 1, 2014 08:39 PM
68442CONVERTCO
Mar 6, 2011 09:17 PM
ralsy
Jul 8, 2010 05:10 AM
Nailhead 88
Jun 3, 2008 08:09 AM
stew6371
Jan 14, 2007 08:36 PM
