no gas flow 1968 cutlass mechanical pump
Old Jun 9, 2025 | 11:19 PM
blp's Avatar
blp
I replaced mechanical fuel pump and the in-line filter that is before said pump. I have no gas making its way even to the filter..... uhhhgg
car sitting in parking lot of a business and I gotta find a fix fast..
ty as always
Old Jun 10, 2025 | 01:32 AM
Since any in-line fuel filter installed prior to the mechanical fuel pump is an aftermarket item it's possible to suspect the in-line filter may have been installed incorrectly? Since there is no indication of the product number &/or manufacturer stated in your post, I'd suggest you examine the in-line filter to ensure it's installed correctly. Generally, I believe there is an arrow on most filters indicating flow direction - was it installed backwards?
Old Jun 10, 2025 | 03:31 AM
blp's Avatar
blp
it never did this for 2 years until yesterday. So I'm throwing parts at the situation
Old Jun 10, 2025 | 04:08 AM
Tyroma's Avatar
Throw an electric pump in until you can re-build or replace the mechanical one. It will get you home.
Old Jun 10, 2025 | 04:22 AM
JohnnyBs68S's Avatar
A leak in the fuel line between the tank and this aftermarket filter could hinder the pumps ability to draw fuel from the tank and instead pull air in through the leak. There are a few places where the factory used a short length of rubber hose to get around corners (tank pickup to line and through the frame behind the RF wheel are two places that come to mind). The aftermarket fuel filter is another in your case. I'd start there.
Old Jun 10, 2025 | 04:53 AM
Sugar Bear's Avatar
Is there definitely gas in the tank? Even if there is add some as the fuel sock filter in the tank may be partially clogged preventing supply flow to the pump.
Old Jun 10, 2025 | 05:32 AM
Tyroma's Avatar
YES to this! Try blowing compressed air through the fuel line from the engine side back to the tank. Sometimes the sock in the tank gets saturated with crud and stops the flow. I did this trick on a few project cars. Once the sock is off, the filter will catch any chunks that get sucked up.
Old Jun 10, 2025 | 05:39 AM
Run the fuel hose IN to the fuel pump from an auxiliary fuel tank. This eliminates all the fuel lines and hoses from the tank to the fuel pump.
Old Jun 10, 2025 | 05:50 AM
Sugar Bear's Avatar
If you blow air into the tank, remove the fuel cap first and keep the pressure low to prevent rupturing the tank.
So, yesterday you replaced the mechanical fuel pump AND the in-line fuel filter prior to (downstream of) the mechanical fuel pump. You are aware the mechanical fuel pump DRAWS (SUCKS) fuel FROM the fuel tank, correct? If you disconnect the fuel line running between the mechanical fuel pump and the fuel tank AT the fuel tank does fuel flow from the fuel tank?
Old Jun 10, 2025 | 01:51 PM
Put a few gallons of fuel in the tank, just to be sure.
Fill the float bowl of the carb with gas, the engine should run long enough on that to pull fuel from the tank. If it still won’t start, id look at ignition failure.
If it will run on fuel in the carb, but not pull fuel from the tank, inspect all the lines for holes or split hoses. If good, either pump is junk or the fikter in the tank is clogged.
bxd76
Apr 26, 2023 11:57 AM
spyke
Sep 23, 2017 11:01 AM
Big Blue 65
May 14, 2014 12:46 PM
Anakedape
Feb 25, 2014 02:00 PM
1964starfire
Jan 3, 2011 04:05 PM
