72 Supreme Convertible ac firewall to non ac firewall
Old Mar 9, 2025 | 02:56 PM
flameorange's Avatar
Ok newbie question here, has anyone converted a Supreme Convertible (72) AC firewall to Non AC firewall? I was going to just section out enough to weld in the non AC portion to replace the AC version. Asking for a friend 🤪…
Or is there a better way, what am I missing….
Donor firewall
Donor firewall
Removing AC
Removing AC
Old Mar 10, 2025 | 07:24 AM
oddball's Avatar
Your call. You can swap in a complete firewall if you want - it's the same as the Chevelle and readily available in both configurations. Or, if you don't actually want the heater either, you can just block the opening.
Old Mar 11, 2025 | 06:26 AM
The right way to do this is to swap out the entire firewall. As noted, repros are available, however while the Chevelle firewall certainly works, it is not EXACTLY correct for an Olds. This only matters if you are doing a 1000 point restoration on a car like a W30.
You can section in the heater box area. How well this works depends on your butt welding skills.
You can use the aftermarket "A/C delete" box on the current firewall. This requires you to retain the A/C control head on the dash and the vacuum-operated HVAC box under the dash if you want the heat and defrost to work.
You can simply blank it off if you don't want heat/defrost.
Old Mar 12, 2025 | 06:28 PM
No Ordinary Joe
Thank you very much sir, much appreciated…
Old Mar 13, 2025 | 12:41 AM
75 W-30 H/O's Avatar
https://acdelete.com/pages/68-72_A-Body.htm
Old Mar 13, 2025 | 04:11 AM
deadeyejedi's Avatar
I used the aftermarket ac delete cover,for me it was the simplest choice.Question, my 72 supreme firewall has more of a vertical hole in it , the one pictured here is more horizontal was there a difference for some reason?
Old Mar 13, 2025 | 05:19 AM
After waking up a bit I now see the ops first pic is of a non ac donor firewall .
Old Mar 13, 2025 | 01:55 PM
The vertical hole is for a car equipped with A/C, heater only cars get a rectangular shaped hole for the rectangular heater case.
Chatt
Apr 19, 2023 07:37 AM
dc2x4drvr
Jun 15, 2022 08:34 AM
72455
Feb 8, 2022 09:22 AM
bkeese
Mar 7, 2015 05:05 AM
Grace Stinespring-Welch
Jul 14, 2013 07:29 PM
