Wheel well trim
Old Nov 5, 2024 | 03:25 PM
WARS442's Avatar
Wheel well trim
On a 68-69 Cutlass which wheel well trim goes in the front ? The wider ones or the skinny ones. Thanks for you input.
Old Nov 5, 2024 | 03:51 PM
JohnnyBs68S's Avatar
AFAIK, the wheel well trim on the front and rear are the same width. There IS a difference between the trim width on Cutlass S (same as 442) and Cutlass Supreme. But the trim is the same width all around.
Old Nov 5, 2024 | 04:32 PM
WARS442's Avatar
I was referring to the part that goes toward the center of car not the part that is exposed. This may have been off a 442.
Old Nov 6, 2024 | 04:31 AM
Until I just now went to look at mine, I never noticed the difference in widths of the inner lips between the front and rear trim. I would've thought that the differences in the fender / quarter panel contours would've made then non-interchangeable. In any case, the wider lips go on the rear.
Old Nov 6, 2024 | 08:06 AM
442mark's Avatar
Skinnies on front, wider ones on rear.
Old Nov 6, 2024 | 03:38 PM
WARS442's Avatar
Thank you guys.
442iowa
Jan 9, 2023 07:05 AM
nonhog
Aug 22, 2019 03:01 PM
455man
Nov 12, 2013 08:07 AM
costpenn
Body work
Aug 7, 2012 10:07 PM
cutlass tom
May 9, 2011 04:37 AM
