No start 98
Old Jul 19, 2025 | 02:27 PM
Green_Machine's Avatar
‘73 98 Regency
No start 98
I went to drive my olds 98 455 and it drove about 5 minutes before it stopped running at a red light. I tried to restart it on the side of the road and that didn’t work so I had it towed home where it continued to not start. We sprayed starting fluid down the carb and that didn’t work. It has fuel, spark, and adequate air and I don’t think it has any vacuum leaks. However it did have a high idle. Is it possible the adjustment screws are just off? Or what could be the cause?
Old Jul 19, 2025 | 02:34 PM
Yes, if by "adjustment screws" you are referring to the A/F idle mixture screws. Without any additional information, at this point it would be to your advantage to follow the tune-up procedure (in order) in the 1973 CSM. When was the last time the distributor cap, rotor, contact points, condenser & spark plugs were changed?
(1) Set Dwell,
(2) Set Timing,
(3) Adjust A/F mixture screws to achieve highest vacuum (use a vacuum gauge),
(4) Set slow idle stop.
Old Jul 19, 2025 | 02:41 PM
‘73 98 Regency
(1) Set Dwell,
(2) Set Timing,
whole distributor assembly is basically brand new, aside from the wires looking a little old they’re good. It did catch for a second when using starting fluid but died right after so I think the carb.
Old Jul 19, 2025 | 03:18 PM
(1) Set Dwell,
(2) Set Timing,
Old Jul 19, 2025 | 04:46 PM
If it did not start with starting fluid I’m going to guess you have no spark or the plugs are really fuel fouled.
Old Jul 19, 2025 | 05:20 PM
‘73 98 Regency
it did start for a second then died.
Old Jul 19, 2025 | 05:31 PM
Remove one or two plugs & evaluate. Chance they're heavily caked/fouled w/ carbon.
Old Jul 19, 2025 | 05:34 PM
Engines need air (a given), fuel, and a properly timed spark to run. Find which is missing.
Old Jul 19, 2025 | 05:37 PM
‘73 98 Regency
I’ll pull a few plugs and see if it’s getting spark but I’m thinking it’s a carburetor problem
Old Jul 19, 2025 | 05:42 PM
In my experience, starting fluid will get you a couple seconds of run time only.
You can pour gas into the fuel bowl vent to fill the bowl. The engine should start and run that fuel for several minutes.
Old Jul 19, 2025 | 05:44 PM
^^x2^^ Check the plugs for fouling (first). You "might" get away w/ a simple adjustment of ea. carburetor A/F mixture screw. Best to check plugs (first) to see if you might be running rich (causing plugs to foul).
Old Jul 19, 2025 | 06:57 PM
‘73 98 Regency
Alright I’ll pull all the plugs and let yall know what I find hopefully I can get it to run again.
Old Jul 20, 2025 | 06:57 AM
How many miles on the engine? Sadly, your symptoms sound like the timing chain and gears need to be replaced. Check the timing with a timing light while cranking the engine. My money is on it being far off.
Old Jul 20, 2025 | 08:17 AM
Sugar Bear's Avatar
^^^ Could be.^^^
Does it sound like it is cranking a little easier and slightly faster than before? If yes the valve timing is off due to a chain and gear issue.
Old Jul 20, 2025 | 09:09 AM
‘73 98 Regency
I don’t think timing it was running perfectly fine before this just a little bit rich. It’s only got 82,000 miles
Old Jul 20, 2025 | 09:15 AM
‘73 98 Regency
^^^ Could be.^^^
no it cranks the same when I first started it. Plus it came to life for a minute when using starter fluid.
Old Jul 20, 2025 | 09:17 AM
‘73 98 Regency
I can’t get to the car today but I’m thinking fouling since the seller was talking about the car running high idle since he basically just slapped a “new”carb on there and didn’t adjust it.
however I did find the choke was very loose but upon cranking it with the choke manually held closed it didn’t help.
Old Jul 20, 2025 | 10:54 AM
Read my post again. If the timing chain has slipped, which is very common on Olds motors with the plastic cam gear, the timing will be WAAAAAY off, making it easy to determine if this is the problem or not. This is exactly how my 69 Cutlass wagon was acting earlier this year when the chain slipped.
Old Jul 20, 2025 | 11:20 AM
69CSHC's Avatar
Keep it simple Green Machine and work your way up the cost and difficulty ladder...
Check the cables make sure all distributor connections are secure. If not maybe change the plugs, they can get bad enough that a car will go from starting and running to nothing at all surprisingly quickly. If not, maybe timing chain is due if it hasn't been done already...
By the way on a side note, how do you have an active busy thread that you are very actively participating in and "0" posts ...
Old Jul 20, 2025 | 12:26 PM
‘73 98 Regency
I noticed that too I’m just as confused
Old Jul 20, 2025 | 02:00 PM
69CSHC's Avatar
Hey well let me welcome you to the site once again, as you now currently have 1 post registered.
Old Jul 20, 2025 | 02:29 PM
‘73 98 Regency
hooray!
Old Jul 20, 2025 | 03:53 PM
gs72's Avatar
72Cutlass S
If you haven’t touched the distributor, get the timing mark to top dead center and pull the distributor cap and see how close the rotor is to the #1 plug wire terminal on the cap. It should be pretty close. If its looks way off its timing chain time. Usually they jump on decel or when the engine is turned off.
Old Jul 20, 2025 | 04:09 PM
As for the post count, you were flagged as a possible spammer because as a newbie you made 3 or more posts in less than 10 minutes. It got messed up when the posts were moderated. I’ve been working off my phone for the last few days and will try and fix it tomorrow night when I get back.
Old Jul 20, 2025 | 05:17 PM
‘73 98 Regency
oh ok sorry about that
Old Jul 20, 2025 | 05:51 PM
it’s just how the site works, it’s not you.
Old Jul 20, 2025 | 09:03 PM
‘73 98 Regency
So before I went home tonight we went back to the car and shot some more starter fluid down there just for giggles and it kicked for a bit and then died and then wouldn't fire again. Tomorrow I’m swamped but Tuesday I might go back and check for sufficient spark.
Old Jul 20, 2025 | 09:42 PM
In post #1 you stated you have fuel & spark. As suggested, pull a couple plugs & evaluate for carbon caked fouling. You're sure you have fuel "reaching" the carburetor? Generally a faulty fuel pump will show signs of leaking before it fails; although, they can fail w/o showing previous signs of a leak. If you fill the carburetor w/ fuel (as has been suggested) you should be able to get several minutes of run time. During this period of run time, if you pump the accelerator do you see two streams of fuel entering the carburetor?
Old Jul 20, 2025 | 09:59 PM
‘73 98 Regency
it reeks of fuel at the carb and I had my friend look down and see if the jets were shooting and he said yes. All the while I was pumping the life out of the pedal. But I’m not sure he was all telling the truth because I believe the carburetor has issues. But it was running with it. What I did find was the choke was very loose and wouldn’t stay closed. But even when I had my friend hold it closed it still wouldn’t start. I’m convinced spark plugs might be caked especially with the high idle.
Old Jul 21, 2025 | 03:21 AM
The engine needs all those things AT THE CORRECT TIME, thus my suggestion to check the timing chain.
Old Jul 21, 2025 | 04:58 AM
  #31
‘73 98 Regency
it did start on starting fluid briefly but if all else fails I’ll look at that.
Old Jul 21, 2025 | 05:42 AM
  #32
This is my frustration. It is trivially easy to test for this and eliminate it as a potential cause, and takes far less time than we've been talking about it, but you want to do other stuff first. Knock yourself out.
Old Jul 21, 2025 | 06:30 AM
  #33
‘73 98 Regency
So I went back and borrowed my friends timing light in my free time and we determined the car had good timing. I didn’t have enough time to pull spark cos I have work but that will be next.
Old Jul 21, 2025 | 01:27 PM
  #34
What is the timing set to? BTW fixed your post count.
Old Jul 21, 2025 | 02:11 PM
  #35
‘73 98 Regency
8 degrees
and thank you
Old Jul 21, 2025 | 03:45 PM
  #36
Sugar Bear's Avatar
Please explain this more. Was it converted to HEI or is it still points and condenser? Carburetors are rarely the cause of a no start condition.
Glad the timing chain set looks good for now.
Old Jul 21, 2025 | 04:10 PM
  #37
‘73 98 Regency
honestly couldn’t tell you. Pretty sure its points seller didn’t tell me much about the engine other than he threw a quadrajet on it and never adjusted it. I’ll send pics once I get back to the car. Honestly I think I flooded the cylinders out combined with fouled sparkplugs from what everyone’s been saying on here.
Old Jul 21, 2025 | 04:24 PM
  #38
Sugar Bear's Avatar
Yup, get us a picture of the distributor. We may ask for another pic with the cap removed after seeing the first picture.
Old Jul 21, 2025 | 04:26 PM
  #39
‘73 98 Regency
Yup, get us a pic of the distributor.
will do.
Old Jul 21, 2025 | 05:58 PM
  #40
69CSHC's Avatar
Left is Points, Right is HEI
Im guessing Sugar Bear is wondering if HEI, the module could be bad...
